Introduction: Automation AVR OLTC Transformer 150 KV
Automation AVR 150 KV Transformer OLTC
AVR is Automatic Voltage Regulation.
CONTROLLER is functioning raise and lower the high voltage transformer OLTC. And with some additional features that is functioning as a protection OLTC of Flow Indicators and more along Announciator.
Components:
- LCD Shield
- LCD TFT CTE32
- Arduino Mega 2560 R3
- Relay Digital Input 8 Ch
- Transformers 100/5 volt AC input sensors
- 110 VDC Power Supply Circuit Out 5; 12 VDC
- LAN Ethernet Shield,
- Plus complementary components, nuts, bolts, jumper cables, etc.
The workings of the controller monitors the voltage distribution in realtime and give the command Tap Changer when the secondary voltage transformers (Voltage Distribution) at 20:20 kV voltage, the controller will be ordered Tap Changer rose to the position of Tap / leads higher so that the voltage will rise up to 20:50 on the voltage kV Normal center setup. And the numbers will increase in TAP Position 1 and OLTC Counter will increase () 1.
And likewise if dist shows Voltage Voltage 20.80 kV, the controller will command the OLTC to decrease leads to lower voltage to the voltage Normal Dist 20:50 kV, so the TAP Position will be reduced (-) 1, and will continue to grow OLTC Counter () 1 shows the amount of work OLTC.
INDICATOR: The indicator is a sign that will work if the controls do action or get input from the wiring protection system.
- "R", // 1. OLTC RAISE >> COMMAND CONTROLLER
- "L", // 2. OLTC LOWER >> COMMAND CONTROLLER
- "PT", // 3. VO Voltage 22 kV CVT
- "TCP", // 4. TAP CHANGER IN PROGRESS
- "LAN", // 5. LAN / ETHERNET // CONNECTING ETHERNET ACTIVE
- "WD", // 6. Watchdog // THIS BROKEN EQUIPMENT controll
- "A-B", // 7. // BLOCK AVR AVR transformer DAMAGED, REPLACE FUNCTION controll AVR.
- "ANH", // 8. // Healt AVR AVR transformer NOT LIMIT TAP UP / DOWN
- "BYP", // 9. // AVR BY PASS IN NON AUTO SWITCH CONTROLLER BY // controll REPLACE FUNCTION AVR.
- "LOG", // 10. EVENT LOGGER // NOTE ALL ACTION CONTROL AND MEASURRE
So .... We Create Contoller wholeheartedly for efficiency purposes. With the same ability to have even more protection capabilities, then the controller is saving, compared with the product manufacturer that has been widely sold in the market. Innovation is of course fiction by adopting of some fiture which we summarize in one unit controller with regard functions required.
According to the abstract of our controller products for the purpose of founding of an innovation.
A Greeting ...
Works Innovation 2015 INDONESIA.
We Wait ADVICE and Critique of Friends all ...
Thanks..
Thanks..
Thanks..
