Introduction: Autonomous Driving Object Detection on the Raspberry Pi 4!
Here is a demo of the project in action! :)
This project leverages a neural network to detect things on the road that an autonomous driving vehicle would see (eg. bus, traffic light, traffic sign, person, bike, truck, motor, car, train, rider). The trained network was tested on lightweight hardware (i.e. Raspberry PI 4) to see how it performs in terms of processing speed and detection accuracy.
For more information, here is the location for Code, YouTube tutorial (for set up information), and Medium Post (on the training and theory)
Step 1: Open a Command Prompt on Your Raspberry Pi and Clone the Repository
Command:git clone https://github.com/ecd1012/rpi_road_object_detection.git
Step 2: Change Directory to Source Code
Command: cd rpi_road_object_detection
Step 3: Open Command Prompt and Make Sure Pi Is Up to Date
Command: sudo apt-get update && sudo apt-get upgrade
Step 4: Install Virtual Environment
Command: sudo pip3 install virtualenv
Step 5: Make Virtual Environment
Command:python3.7 -m venv TFLite-venv
Step 6: Activate Environment
Command: source TFLite-venv/bin/activate
Step 7: Install Dependencies
Command:bash get_py_requirements.sh
Step 8: Make Sure the Camera Module Is Enabled
Command: sudo raspi-config
- Go to Intercae Options and make sure the Pi Camera is enabled.
Step 9: Setting Up Hardware
This project was configured and tested with the following hardware components.
Here is a video tutorial to set up the hardware: https://youtu.be/Zfmo3bMycUg?t=277
Core
- Raspberry Pi 4 GBRaspberry
- Pi 5MP Camera (rev 1.3)
Other
- LED
- 470 Ohm Resistor
- Small breadboard
- GPIO push button
- 3.5 Amp USB-C Power Supply
Step 10: Connect Pi Camera Module to Raspberry Pi
Connecting the Camera for This Project: https://youtu.be/Zfmo3bMycUg
Additional Help:
Step 11: Connect a Push Button to GPIO Pin 17
This will be used as input to kick off the program.
Connecting Push Button for this project: https://youtu.be/Zfmo3bMycUg?t=437
Additional Help:
Step 12: Connect an LED to GPIO PIN 4
This LED will turn on to indicate when the program is running. Make sure you use a current limiting resistor with the LED!
LED Connection for This Project: https://youtu.be/Zfmo3bMycUg?t=353
Additional Help:
Step 13: Running Detection
Now all the code and software is configured to run object detection!
Mount your Pi in your car and test it out! Drive Safe! :)
Command: python TFLite_detection_webcam_loop.py --modeldir=TFLite_model_bbd --output_path=processed_images
Where the --output_path you specify is where you want images saved.
The script will start running and wait for you to press the GPIO input button to start processing the video feed from the camera. Once you press the button, the green LED will turn on and the pi will start feeding and processing the video stream through the neural network. Processed images will be saved to the '--output_path' you specified over the command line.
If you like, make a video out of the images. You can do this with gif-making software, video-making software, or ffmpeg.
