Introduction: Avi to DVD
This instructable is about how to convert any avi file to DVD video for Free. Also yes Divx codec. Sorry this is only for windows users. Also you will have to download two programs:
Step 1: Downloads and Installs
divxrepair.sourceforge.net
dvdflick.net
1) Go to divxrepair.sourceforge.net 2) Scroll down until you see downloads. 3) Look for the description, “DivXRepair executable” since you want to run the program. Save the executable to somewhere on your hard drive.
1) Go to dvdflick.net, 2) Click on the Download tab at the top. 3) Now click on the text, “Download DVD Flick”. This should send you to sourceforge website and a then the download of DVD flick will pop up. 4) Save the file to somewhere on your hard drive.
After downloading the software please install them to your preferred location.
Step 2: Repair Your Divx Avi
When would you know if you need to repair a divx file
If you are not using a divx codec please skip this step.
If you are playing avi files, you may have noticed one of the following things:
- Suddenly the image froze but the sound kept playing.
- Disoriented or equally coloured blocks of pixels distorted the image for a time.
Step 3: Add One or More Avi Files to Add to the Title.
Step 4: Configure Your Project
The only thing you really need to set here is the Target size under the General tab, and the Target format, and Encoding profile under the Video tab.
For Target Size, choose the size of the disc you will be burning your project onto. Usually the default setting of DVD-5 (4.3 Gb) will be fine, but if you wanted to use a dual layer disc or any other common format, you can select that as well.
For Target Format, you must choose which format is used on the standalone DVD Player you will be watching the DVD on. For most Europe, Asian, African and Oceanic countries this should be set to PAL, for most American countries to NTSC. Some DVD Players support both formats, in which case you should select the Mixed format. When using the Mixed format each separate title will be determined to be either PAL or NTSC, and encoded as such.
For Encoding Profile, you must make a trade-off between the time it will take to encode the DVD, or the quality thereof. Generally Fast offers reasonable image quality, the difference between Normal and Best is almost unnoticeable. Though if you are going to make a DVD that is near or over 3 hours in length, it is not recommended to choose Fast but Normal or Best instead or the image quality will suffer.
Step 5: Choose a Destination Folder
Step 6: Enable Burning DVD or Iso
To enable this, check the Burn project to disc option under Project Settings, and the Burning tab.Disc label can be set to the label of the disc as displayed by your computer, but is not used by DVD players. Be sure to select the right drive to burn to, and to insert an empty disc in it before starting the encoding.
If you would rather have just an ISO image of the DVD to burn at your own leisure, only check the Create ISO image option, and enter a disc label.
Step 7: Encoding And/or Create DVD
When you are all done creating your project, be sure to save it first. Then press the Create DVD button and the encoding process will start, providing you have enough free disc space. How long the encoding takes is very much dependent on the speed of your CPU, and the hard drive that the project's destination folder is on. It's best to let your PC do this during the night, or during a very long coffee break.
Step 8: Add Subtitles (Optional)
To edit the language, font, font size and positioning of a subtitle select it and press the Edit button. In the window that pops up you can change various properties of the subtitle. When you click the small preview you will see a larger approximation of how the subtitle will look.
The language setting is simply the language of the subtitle in question. The character set option is used to indicate in what way the subtitle file is encoded, so that the right characters can be drawn. For example if you have added a Chinese subtitle, you might have to set the character set to Chinese BIG5 or GB2312.
The Auto-fit button will adjust the subtitle's font size so that all subtitle lines will fit on screen. The display by default button will make sure that the current subtitle will be displayed automatically when the title containing it is played. If other subtitles have this set, only the first subtitle in the list will be displayed when the title starts.
Step 9: Add Audio Tracks (Optional)
After you have added the title, edit it and go to the Audio tracks tab. There you can press the Add button, and then select the audio file or another video file that you will choose an audio track from. If you chose a video file or the file you chose has more than one audio track, you will be asked to choose which track to add.
