Introduction: Avocado Netting Shirt
The fashion industry creates waste from discarded materials and lacks of recycling processes. Up-cycling old clothes is a way we can get rid of some of this waste. My favorite food is avocados, they come in net bags that create waste. For these reasons I decided to make a shirt out of a dress that I no longer wore and the bags avocados come in.
- Old clothing
- Avocado netting bag
- Thread
- Sewing Machine (optional) *you can hand sew*
- Loop turner
- Scissors
- Paper
- Pen
- Ruler
- Tape measure
Step 1: Saving Netting and Finding Fabric
- Save the bags that avocados come in and cut off the plastic pieces
- Find scrap fabric from an old sewing project you were doing or old clothes as your fabric, I’m using the bottom of a dress I don’t wear *works better with stretchy fabric*
Step 2: Making Pattern 1
make a pattern that will fit you
- To make a pattern that will fit, measure from under your arm to the middle of your chest, this will be the bottom of the triangle my measurement is 9 1/2 inches
- Then find the half way point of that line and draw a line straight line up the paper from it
- The second measurement is the right side of the triangle, to get this measure from under your arm to the top of your collarbone My measurement is 14 inches
- Use the second measurement for the other side of the triangle
- Measure an inch down from the top of the triangle and draw a line
- Cut pattern piece out
Step 3: Cutting Pattern 1
- Cut your fabric so it lays flat
- Trace this pattern four times on your fabric (you can use chalk to trace it on, I used a pen)
- Cut the fabric
- Cut the netting so it lays flat
- Place the netting over one of the triangles you already cut out covering as much as you can
- Cut off the excess netting
- Repeat this step one time and make the netting look the same as the other *You can leave the two inner corners without netting later on you won’t see the two corners I left the top with no netting because I liked it like that*
Step 4: Making Pattern 2
now that the cups for the shirt are cut out, we need to cut the bottom of the shirt
- To find your measurements for this you need to measure from under one arm to under the other, my measurement is 15 inches
- Then draw two inch lines up from each end of the line
- Find the middle of your first measurement and draw a straight line up through the page
- Connect the ends to the center line at a point
Step 5: Cutting Pattern 2
- Trace Pattern 2 on your fabric two times
- Cut the fabric
Step 6: Making the Straps
- cut out one inch wide strips of fabric with the length that measures from under one arm to the other arm, my measurement is 15 inches
- Now fold them in half and sew along the side that is open
- Then sew one end shut and leave the other open
- Using a loop turner, turn the strap inside out
- Repeat these steps for the other 3 straps
Step 7: Sewing Pattern 1
- Lay one of your cut of triangles down
- Place the netting over top of it
- Then lay one strap leaving about 1/2 inch of the strap that is not sewn shut, out the top of the triangle
- Place a second triangle over top of that
- Sew along the edges leaving the bottom of corner that doesn’t have netting, left unsewn
- Now turn insider out using the bottom piece you left unsewn
- Repeat 1-6
Step 8: Sewing Pattern 2
- Lay your two pieces for the bottom of the shirt together and sew the bottom of it
- Then unfold it
- Put a strap in the center with the unsewn side of the strap 1/2 inch out
- Then fold back over
- Now sew along the edge with the strap
- Unfold
- Put a strap in the center with the unsewn side of the strap 11/2 inch out on the other side
- Fold back over
- Sew along the edge with the strap
- Turn inside out
Step 9: Attaching Pattern 1 and 2
- Place one triangle piece down
- Then place the bottom of the shirt on top by laying it right above the corner where there is no avocado netting like shown
- Sew along the highlighted part
- Now cut off the excess of fabric
- Place the other triangle down
- Place the bottom of the shirt the same as you placed the other one
- Sew along true highlighted edge
- Then cut off the excess fabric
- Finally fold down the bottom of the shirt and uncross the triangles and you are done
