Introduction: Awesome Project With Wall Clock
Hii Friend,
This blog will be awesome bacause in this blog I will make an amazing LED effect circuit using Old Wall clock.
Let's get started,
Step 1: Materials Required
Materials name are given below that we will need to make this circuit.
(1.)Wall Clock Machine x1
(2.)Battery - 9V x1 (Here I am using 9V Battery with 220 ohm resistor but we can also use 3.7V Battery without resistor)
(3.)Battery Clipper
(4.) Resistor - 220 ohm x1 (When we will connect 3.7V Battery then we don't need to use any resistor)
(5.) LED - 3V x2 (Red and Green)
That's all components
Step 2: Open This Wall Clock Machine
Hey gues we will not be required all components of this machine, Only we need it's internal circuit.Hence Open this machine.
Step 3: Remove This Part
We have to remove this part of this machine.
Step 4: Dissolder the Coil Wire
Here in this circuit we need only kit.So dissolder the coil wire and remove the kit.
Step 5: We Need This Kit
This is the kit that we will need in this project.
Step 6: Connect Green LED
Connect Green LED to this kit at the place of coil wire that was soldered.
Solder +ve leg of green LED to one point of coil and
Solder -ve leg of green LED to another point of coil of the kit as you can see in the picture.
Step 7: Connect 220 Ohm Resistor
Solder 220 ohm resistor to this kit at the place of battery as solder in the picture.
NOTE : If you are using 9V Battery then connect 220 ohm resistor otherwise if you are using 3.7V battery then we don't need to solder 220 ohm resistor.
Step 8: Connect Battery Clipper Wire
Now we have to connect battery clipper wire to this kit.
Solder +ve wire of battery clipper to 220 ohm resistor and
Solder -ve wire of Battery clipper to other point of battery as you can see in the picture.
Step 9: Now Connect Battery
Now our circuit is ready so connect battery to battery clipper and see LED will blinking like as ambulance light.
Step 10: Connect Red LED
Connect Red LED to the kit just opposite legs with Green LED as shown the polarity of LEDs in the picture.
Step 11: Now Connect Battery
Now connect battery to battery clipper and see the effect of LED Blinking.
Both LEDs will blink alternate.
Thank you
