Introduction: Axe Restoration
About: Canadian Craftsman
Having fires is a big part of living in a colder climate. A proper axe is an absolute must to keep your wood pile stacked and your wood stove burning.
In this Instructable, I will restore an old axe. I will also showcase necessary maintenance required for this tool;
  • Fitting a new handle.
  • Sharpening the blade.
  • Preventing corrosion.
Follow the steps below and for further clarification, reference the attached video.
Materials:
  • old axe head
  • axe handle
  • boiled linseed oil
  • scrap wood for a wedge
  • wood glue
Tools:
  • knife
  • belt sander
  • palm sander
  • skotch-brite
  • electrical tape
  • hammer
  • punch
  • cordless drill
  • drill bit
  • latex gloves
  • sand paper
  • vice
  • band saw
  • file
  • mallet
  • angle grinder
  • flap disk
  • wire wheel
Step 1: Repair Axe Head
  • Remove old handle wood that is stuck in the eye.
  • Drill a couple holes into the wood and punch it out.
  • Remove rust and paint with a wire wheel.
  • Remove dents with a flap disk, belt grinder, palm sander.
  • Apply a chamfer on the hammer end of the axe head with a metal file.
  • Use a fine grit metal file to sharpen the edge of the axe. Run it along the edge of the blade on both sides. Make sure to maintain a 30-40 degree angle.
  • To clean off the file marks and sharpen further, wet sand the edge of the blade with 400 grit sand paper. Wrap the sand paper around a small, flat piece of wood and sand in a circular motion along blade tip.
  • In the last three pictures you'll see I polished the tip of the axe blade - utilizing electrical tape to mask and skotch-brite to achieve a semi polish. This was for aesthetics and not necessary.
Step 2: Prepare Wooden Handle
This specific axe head falls into the 'camping hatchet' category so the appropriately sized handle was selected. These handles are coated with a Polyurethane from the factory and that is not good for grip, so we need to remove that coating and expose the bare wood.
  • Using a sharp knife manually scrape the entire surface of the handle to remove the factory coating.
  • Smooth the scrape marks with sandpaper.
  • File the top of the handle to fit the eye of the axe properly .
  • Slowly remove material with a file until the handle will go into the eye the slightest bit.
Step 3: Assemble
  • Fit the axe head onto the handle so that it is snug and will not fall off.
  • Tap head onto a wooden work surface until top of wood handle is flush with top of eye on axe head.
  • Hang the axe with one hand and with a mallet, hammer the butt end of the handle. The force of the blow with bring the axe head closer up to the shoulder of the handle (refer to video for a better visual).
  • Trim excess material on the handle to about 1/2" from the axe head.
  • With a small piece of scrap wood, create a wedge with a belt sander. You do this by placing the scrap wood against the belt sander and applying force to one side. This will create a wedge shape. The wedge is a safe guard so your axe head will not fly off the handle.
  • Apply wood glue to wedge and insert into the kerf on the handle.
  • Hammer in the wedge until it basically won't go in any further.
  • Trim excess with a band saw.
  • Sand smooth with a belt sander.
  • Apply boiled linseed oil onto axe head as well as on the handle (ensures no rust will form and wood will not dry out). Wipe excess oil with a rag.
The axe is ready to be put to work now! Thank you for following along.
Step 4:
