Introduction: BB Catching Low Power Bb Gun Target
This target is good for low power BB rifles/pistols, and looks cool when shot because it holds the BB'S in the target. Don't use it with a rifle stronger than 350fps. If you have questions or recommendations, please comment below.
Step 1: Supply's
- one piece of 5" by 4" plywood.
-Duck tape
-skewers
-one piece of 6" solid wood (above duck tape in image)
Step 2: Tools
-drill
-Drill bit the diameter of the skewers
Step 3: Drilling
For this step, you drill 2 holes, one on each side of the 5 inch piece of wood. Make sure that the hole will allow the skewers to fit in it.
Step 4: Attaching Skewers
This step is simple. Just slide the pointed end of the skewers into the two holes.
Step 5: DUCK TAPE!!!
So, now you need to cover one side of the plywood piece in Duck Tape. BE CAREFUL, IT IS EAST TO GET NASTY SPLINTERS!
NOTE- If you cover the back, it will ensure that the BB dose't penetrate it.
Step 6: Attaching the Target to the Stand
Ok, this one is easy. All you need to do is use one strand of duck tape to attach the target over the top part of the stand. Make sure that the duck tape is holding both sides.
Step 7: SHOOTING
Now all you need to do is stick the skewers in the ground to it looks like a gong.
-I AM NOT RESPONSIBLE FOR YOU
- USE FIREARM SAFETY
