Introduction: BBC MIcrobit Bot Using the L9110 Motor Controller
I wanted to connect the BBC Microbit to a standard motor driver board like the L9110 or the L298N. The Micro Bit (also referred to as BBC Micro Bit, stylized as micro:bit) is an ARM-based embedded system designed by the BBC for use in computer education in the UK. This little device is a very compact microprocessor with bluetooth and an accelerometer built in, and a 5 x 5 led matrix for simple messaging. more info on tis micro controller can be found at microbit.org.
There are a number of motor boards available for the microbit, but I had a number of others lying around which are cheap and it gave me a chance to see how to use the extra connections available on the microbit.
I wanted to make a bot that I could add extra sensors and using the L9110 would drive 2 motors so my bot could drive around.
This instructable is only going to detail using the L9110 and adding the motors a simple chassis. The same process could be used to add an L298N instead.
Step 1: Required Hardware
- BBC Microbit
- Microbit edge connector link
- 2 x motors and wheels of your choice, I used Tamiya motors with gearboxes. link
- 4 x AA battery box for the motors, rechargable batteries or a power supply of your choice
- Some plastic strips or other to make a chassis out of. I used a couple of these link
- L9110 Motor driver board
- female to female leads to connect microbit edge connector to L9110 link
- 1 x caster wheel from DIY shop / store
- Some plastic sheet, I used some A4 sheet plastic sheets 1.5mm thick, which you can score with a knife and snap, or can cut with scissors. This is great for panels on your chassis to to build sides later on and enclose all the elecronics. link
- Wheels for your bot
Step 2: Build Chassis
Cut 2 of the plastic strips so you can attach the microbit edge connector I found this was a same width required to fit the Tamiya motor and gearboxes.
Fit the motors which are about the same width as the Tamiya motors and have a single mounting hole.
Fit caster wheel
This will then give you a basic chassis for your bot, that you can use with the microbit.
Step 3: Connecting Things Up
At this stage you can slot in the microbit to the edge connector, it can go either way up as the edge connector works both ways.
Full details of the pin outs of the bbc microbit can be found here. I didnt know which were the best pins to use then I looked at a link to a manual on a ready made driver board from Kitronik designed for the microbit which I found here.
This showed me which pins this ready made board used, and also gave a code sample I could adapt for use.
Motor 1 uses Pin 8 and Pin 12 on the microbit
Motor 2 uses Pin 0 and Pin 16 on the microbit
For an explanation how to use the L9110 controller you can read more detail here but below is how I connected it up. detailed L9110 description
Connections
L9110 ---> Microbit
A-IAMotor A Input A (IA) ---> Pin 8
A-IBMotor A Input B (IB) ---> Pin 12
B-IAMotor B Input A (IA) ---> Pin 0
B-IBMotor B Input B (IB) ---> Pin 16
VCC ---> AA Battery Pack +
GND Ground ---> AA Battery Pack -
You also need to connect the GND from the L9110 to the GND on the Microbit edge connector.
Step 4: Testing With Code
To prove the connections worked I modified the example shown for the Kitronik motor controller document.
The microbit has a number of language options which means you can try this a number of different ways.
This example uses the Microsoft touch development environment which can be found and used online here https://www.microbit.co.uk/.
The code example attached just drives the motors forwarded when you press button A, and stops when you press button B.
Use the truth table image to work out the combinations required to make the motors do what you want, and then edit your code.
For my testing I used a separate power supply for my microbit, if you purchase a ready made motor driver board for the microbit, they can power the microbit and motors from the battery power pack or your preferred power source.
I have purchased a couple of these ready made boards so I write future updates using the microbit.
7 Comments
4 years ago
I 9 volts to much for the motors, or no?
Reply 4 years ago
I would try and limit the voltage these motors a max of 6v, 9v may run them hot and burn them out eventually, however the motor controller L9110 can handle that ok.
4 years ago
Thanks so much for your help. I've got it working now and have posted a copy of the MU Python Microbit editor code here for anyone else interested
https://twitter.com/CompSciTeaching/status/888076781923831808
4 years ago
Apologies for the stupid question but as there is only 1 ground pin on the L9110 board how to you connect it to the battery pack and the ground pin on the breakout board?
Reply 4 years ago
Hi you kind of have 2 choices, I have found when using different motor control boards you often need to connect your power source (batteries) via the ground to the ground on the controller, its the same for a Microbit, Arduino or Raspberry PI.
Options 1: (which is what i did here) was I cut the jumper wire and then added another two it and then added a little solder and then covered the joint in heat shrink. so I had one GND output from the L9110 going to two output jumper wires.
Option 2 is the edge connector I used for the microbit has a section you can add more pins to plug in jumper wires so you can solder 2 pins to the edge connector, and then just use the standard jumper wires which will slot onto the 2 pins which are both connected to the Microbit. That probably wasnt explained too clearly but I hope you get the idea. If not let me know I can take a pic of what I mean if that helps.
Reply 4 years ago
Thank you for your quick reply. I think I get what you mean by option 1. If you could post some more photos that would be great. Also could you provide some screenshots of the touch development code? I'm using MuPython editor but should be able to convert it if I can see the block code. Thank you once again.
5 years ago
Interesting motor controller. I might have to try this out with my next robot.
