Introduction: BBQ'd Stir Fry
This BBQ's stir fry is delicious and nutritious. It has a an Italian flair but also maintains the smoky flavor of the grill. It's easy to prepare. Keep your stir fry colorful, as bright colored vegetables are chalk full of antioxidants as well as vitamins.
However it does require the use of a BBQ grilling pan, so if you don't have one you'll want to purchase one.
Prep time is about 40 min.
Cook time 20-30 min depending on BBQ heat.
Step 1: Gathering Ingredients
Ingredients required:
1 1/2 lb sirloin steak
1/4 of a large Spanish onion or 1 medium sized red onion
1 red bell pepper
1 yellow bell pepper
2 small zucchinis
Florets from 1/2 bunch of broccoli [ omitted here as I forgot to purchase it :( ]
1/4 cup lemon juice or juice from 1/2 fresh lemon.
1/4 cup balsamic vinegar
3/4 cup olive oil
3 tbls Clubhouse (McCormick in US) Roasted pepper and garlic seasoning (or similar Italian style seasoning)
1 tbl Clubhouse Vegetable seasoning
1 cup sundried tomato salad dressing
1 red bell pepper
2 small zucchinis
3/4 cup olive oil
Step 2: Prep'ing the Meat To
Remove steak from packaging.
Blot the meat with paper towel to remove any excess blood.
Trim any fat off the surrounding edges.
Thinly slice the meat in slices about 1/8 in.
Cut away any grizzle or fat as you slice.
Place the sliced meat in a bowl.
Add lemon juice and balsamic vinegar. Mix the meat.
Add the 3 tbls of Clubhouse (McCormick in US) Roasted pepper and garlic seasoning (or similar Italian style seasoning)
Add 1/2 cup of olive oil.
Mix well making sure the liquid is covering every strip of meat.
Cover and set in the fridge till your ready to grill meat.
Step 3: Prep'ing the Veggies
Wash the vegetables and trim off stems and seeds.
Dice the vegetables in chunks.
**Broccoli florets should be blanched in boiling water for about 30 sec to 1 min (this will give them that beautiful green color).
**Remove from heat and drain and rinse in cold water to stop cooking process.
**Set broccoli aside.
Place all the vegetables, except broccoli, in a large bowl.
Add 1 tbl Clubhouse Vegetable seasoning, salad dressing and 1/4 cup olive oil.
Mix well till all the veggies are well covered with the oily liquid.
Set them aside.
**I forgot to purchase broccoli so i have no photos. However i have included the steps.
Set them aside.
Step 4: Pan Prep and Preheat.
A BBQ purfarated pan is required for this stir fry.
Light the BBQ to preheat on high.
Spray pan with cooking spray or coat with olive oil.
Place pan on BBQ grill to preheat.
Step 5: Grilling
Toss a few veggies in the pan to make sure it's hot enough. It should sizzle and smoke immediately.
Add the remainder of the veggies from the bowl careful not to scoop up the liquid on the bottom.
Toss the veggies and close the lid.
Turn heat to med.
Add Broccoli to remaining liquid in bowl and toss to coat .
Open lid and toss the veggies around often.
Grill about 10-15 min (depending on BBQ)
Once you see a little color add in the broccoli. (it take way less time to cook)
The veggies should have grill marks and be turning golden brown.
Scoop out the veggies to a covered dish.
Remix meat to coat with marinade oil.
Scoop the meat onto the grill pan avoiding most of the liquid.
Toss meat till starts browning but it should still have pink.
Re-add veggies and toss to reheat.
Remove from heat.
Scoop out the stir fry into the covered dish and let it rest at least 5 min.
Turn heat to med.
Remove from heat.
Step 6: Serving
This stir fry will feed about 3 people if served on it's own. If your serving with a side, like rice then it will feed 4 people easily.
Enjoy!
Hope this tutorial is helpful. Thanks for taking the time to look at it.
Lynne :)
Enjoy!
Lynne :)
