Introduction: BEDSIDE LAMP LANTERN
hello, this is my first public statement, sorry for my English and any errors in the guide.
Taking a cue from the following:
-Bedside;
I created a lamp by transforming the ikea rotea candle holder
Step 1: Necessary Tools and Materials
- Tools :
- Drill and tip of 1 cm
- pliers;
- screwdrivers,
- stripper
- Materials:
- Tea Light Lantern ("Rotera" from IKEA),
- Retro Vintage Twist Braided Fabric Cable
Antique E27 Light Bulb Screw
Grip Clamp
current switch retro style and the plug
retro style LED lamp (E27)
spray paint color copper
threaded bar hollow and nut
Step 2: Spray Painting
First you have to remove all the glass from the lamp.
then the candle holder is drilled in the upper part, with a 1 cm hole, in which the threaded rod will be inserted.
Once all the drilling residues have been removed, the whole is painted.
I painted too Grip Clamp.
Step 3: Assemble the Lamp
Cut the threaded bar of 5 cm you can proceed to assemble the whole.
After passing the cables through the threaded bar, screw the lamp holder into it at the bottom.
screw the nut in the upper part to adjust the height of the lamp, then lock it all with the Grip Clamp.
Once you have inserted the electrical iterator, the plug and the light bulb, you're done. your bedside lamp is ready to use
Step 4: Upshot
Ready a retro style bedside lamp.
Trash to Treasure
4 Comments
Question 4 years ago on Step 3
Grip clamp ? Did the glass go back in ?
I would hide the electrical cord someway . All in all I like it very much .
Answer 4 years ago
Grip clamps are the clamps positioned above the lamp to hold the wire.
The glass has been dismantled for painting
5 years ago
It turned out great :)
Reply 5 years ago
Thank you so much
