Introduction: Bitcoin-like Crypto Running on Raspberry Pi
Instructions for running a node.
The US-OS Operating System is made of raspbian running the us-cryptoplatform package.
You don't have to ask for permission to join.
Just follow these simple instructions and run a node earning cryptocurrency every minute,
with negligible cost in hardware, energy or bandwidth.
This instructions are quite old, please use the Tor-browser to access http://otheravu4v6pitvw.onion
and have the latest status of the project, FAQ and downloadable files.
An usual configuration is when you have:
* Internet Router with a *public* IP4 address (either static or dynamic).
* Raspberry PI 3B+ with at least 16GB of SDCard capacity.
* An Android mobile or tablet.
* A laptop with SDCard reader at hand for the initial setup.
Step 1: Set Up
In your laptop/computer:
download and install the Tor browser from http://torproject.org
Use Tor to access this URL:
Step 2: Have USOS Operating System Downloaded
US-OS is an operating System for Raspberry Pi derived from raspbian, which is derived from debian.
US-OS comes with all the needed software configured.
Follow the node-setup instructions at:
http://otheravu4v6pitvw.onion/downloads/os/node_se...
Step 3: Record the SD Card
Step 4: Assemble Pi and Connect to Router
Insert the SDCard with USOS Operating System into the raspberry PI.
Connect the raspberry pi to your home router using a (short) ethernet cable.
Power Up the raspberry pi.
Check your Router
UPNP shall be enabled. The node needs to program port forwarding for the following ports:
16671
16672
16673
16680
Step 5: Find Out the Local IP Address of Your Node
from windows use putty to login to the node using its LAN address port 16671
