Introduction: BLUE LED RING
About: If you can't make it simple,you don't have right to make it...
THIS IS A RING VERY EASY TO MAKE AND CAN BE MADE IN LESS THAN 30 MINUTES
Step 1: MATERIALS REQUIRED
SOLDERING IRON
BATTERY
WIRE
LED STRIP
FLUX AND SOLDERING WIRE
Step 2: CIRCUIT DIAGRAM
EASIEST CIRCUIT DIAGRAM EVER
Step 3: DESOLDER THE LEDS FROM THE STRIP
DESOLDER 13 LEDS FROM THE STRIP
Step 4: THE SMD LED
IT IS A VERY SMALL SURFACE MOUNTED DEVICE LED WHICH HAVE VERY HIGH POWER NO HEATING AND A LOT OF BRIGHTNESS TOO
Step 5: START ATTACHING THE LEDS TO THE WIRE
AND MAKE THE RING PATTERN OF YOUR SIZE AND CHOICE
Step 6: THE FINAL LED PRODUCT YOU WILL GET
TAKE CARE OF THE POLARITY - POSITIVE, NEGATIVE OF THE LEDS
Step 7: THIS IS THE FINISHED LED.RING YOU NEED TO CONNECT WITH a POWER SOURCE
CHOOSE A POWER SOURCE LIKE I HAVE USED A 3.7 VOLT LI ION RECHARGEABLE MOBILE PHONE BATTERY
Step 8: SOLDER THE WIRES WITH THE LED
ALSO ATTACH THE BATTERY
MAKE SURE THAT THE THINNER WIRES YOU ATTACH THE BETTER IT WOULD BE
Step 9: ATTACH IT TO YOUR HAND
PUT IT ON YOUR FINGER AND USE SOME RUBBER BANDS TO HIDE THE WIRE OR PUT DOWN YOUR SLEEVES
Step 10: LIGHT TESTING
Step 11: TIME TO LIGHT IT UP
ENJOY EVERYWHERE FROM PARTIES TO MARRIGE RING CEREMONY OR TO SHOW OFF YOUR FRIENDS
