Introduction: BMP180 Y LCD Con Arduino
este tutorial les ayudará a todos aquellos que quieran hacer funcionar el sensor de temperatura y presión BMP180 y el LCD a través de arduino.
Step 1: Materiales
para que este programa nos salga bien debemos tener los siguientes materiales:
cables
Arduino
cable usb
potenciómetro
LCD
BMP180
computador
Step 2: Montaje
Step 3: Codigo
para hacer funcionar el bmp180 y el LCD se tienen que fusionar dos códigos que son el de hello world y el original del sensor de temperatura bmp180. El código seria ell siguiente:
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal library works with all LCD displays that are compatible with the Hitachi HD44780 driver. There are many of them out there, and you can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD and shows the time.
The circuit: * LCD RS pin to digital pin 12 * LCD Enable pin to digital pin 11 * LCD D4 pin to digital pin 5 * LCD D5 pin to digital pin 4 * LCD D6 pin to digital pin 3 * LCD D7 pin to digital pin 2 * LCD R/W pin to ground * LCD VSS pin to ground * LCD VCC pin to 5V * 10K resistor: * ends to +5V and ground * wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008 by David A. Mellis library modified 5 Jul 2009 by Limor Fried (http://www.ladyada.net) example added 9 Jul 2009 by Tom Igoe modified 22 Nov 2010 by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal *
/ include the library code: #include #include #include
// initialize the library with the numbers of the interface pins LiquidCrystal lcd(12, 11, 5, 4, 3, 2); SFE_BMP180 pressure;
double PresionBase;
double Presion = 0; double Altura = 0; double Temperatura = 0; char status;
void setup() { // set up the LCD's number of columns and rows: lcd.begin(16, 2); Serial.begin(9600); SensorStart(); }
void loop() { // set the cursor to column 0, line 1 // (note: line 1 is the second row, since counting begins with 0): lcd.setCursor(0, 1); // print the number of seconds since reset: ReadSensor(); //Se imprimen las variables
lcd.print("Temperatura: "); lcd.print(Temperatura); lcd.println(" grados C"); lcd.print("Presion: "); lcd.print(Presion); lcd.println(" milibares"); delay(1000); } void SensorStart() { //Secuencia de inicio del sensor if (pressure.begin()) Serial.println("BMP180 init success"); else { Serial.println("BMP180 init fail (disconnected?)\n\n"); while (1); } //Se inicia la lectura de temperatura status = pressure.startTemperature(); if (status != 0) { delay(status); //Se lee una temperatura inicial status = pressure.getTemperature(Temperatura); if (status != 0) { //Se inicia la lectura de presiones status = pressure.startPressure(3); if (status != 0) { delay(status); //Se lee la presión inicial incidente sobre el sensor en la primera ejecución status = pressure.getPressure(PresionBase, Temperatura); } } } } void ReadSensor() { //En este método se hacen las lecturas de presión y temperatura y se calcula la altura //Se inicia la lectura de temperatura status = pressure.startTemperature(); if (status != 0) { delay(status); //Se realiza la lectura de temperatura status = pressure.getTemperature(Temperatura); if (status != 0) { //Se inicia la lectura de presión status = pressure.startPressure(3); if (status != 0) { delay(status); //Se lleva a cabo la lectura de presión, //considerando la temperatura que afecta el desempeño del sensor status = pressure.getPressure(Presion, Temperatura); if (status != 0) { //Se hace el cálculo de la altura en base a la presión leída en el Setup } else Serial.println("error en la lectura de presion\n"); } else Serial.println("error iniciando la lectura de presion\n"); } else Serial.println("error en la lectura de temperatura\n"); } else Serial.println("error iniciando la lectura de temperatura\n"); }
este es el código del programa, pero instructables no lo deja poner como en realidad es porque quita los espacios que hay entre cada parte del código.
Step 4: Resultado
finalmente, después de correr el programa y subirlo a Arduino le deberá aparecer lo siguiente en el LCD.
