Introduction: Null
By modifying the front and rear panel Iv'e designed a projected sound speaker cap/face panel which will make the speaker much louder in a large projected area. The face panel then connects into the rear panel using the skinnier rods which slip thru the front face clearance hole and fit snug into the hole on the opposing side. The four corner rods slip thru as well, then using the knob, thread into the threaded hole on the rear panel. The threaded rods and skinnier perimeter rods should greatly strengthen the lock of the air tight seal along with protecting the core cube from any mishaps. The large Suction cup on the rear panel which would be secured with the BOSE most practical solution team (recessed and glued to prevent sag recommendation) makes this cube very versatile and still small enough to be easily portable.
