Introduction: BUILDING a 60000 VOLTS VOLTAGE MULTIPLIER
HELL AND WELCOME BACK !!!!
AS BEING A FAN OF PLASMA ARCS I WANTED TO BUILD SOME HIGH VOLTAGE JUNK !!! SO INITIALLY I MADE A HIGH VOLTAGE FLYBACK PLASMA POWER SOURCE BUT I WANTED EVEN BIGGER ARCS !!
BUT I WANTED EVEN MORE ARCS !!!! BIGGER ONES SO I WENT TO THE SUPREME GENERATOR THE VOLTAGE MULTIPLIER !!!!
AND I WAS JUST AMAZED BY THE ARCS AND I AM GLAD TO SHARE IT WITH YOU ALL !!! HOPE YOU ALL WILL ALSO GET FASCINATED !!!!
Step 1: WATCH THE VIDEO FIRST
THE VIDEO BASICALLY EXPLAINS EVERYTHING VERY WELL!!!!
HOPE YOU LIKE IT SHARE AND SUBSCRIBE !!!!
Step 2: PREVIOUS PLASMA POWER SOURCE VIDEO
Step 3: DILEMMA OF AC VOLTAGE
I HAD TWO CHOICES TO GRAB UPON ONE BEING THE USE OF MAINS 220 VOLTS OR HIGH FREQUENCY FERRITE TRANSFORMER BUT BUT BUT !!!! IT IS SERIOUSLY VERY DANGEROUS IF ANYTHING GOES WRONG AND IT TAKES LONG TIME TO CAPS . BUT DONT TRY IT !!! IF YOU VAUE YOUR LIFE !! SO I CHOOSE TO USE HIGH FREQUENCY 17-20 KHZ FERRITE TRANSFOMER
WHICH WE WILL WIND ON OUR OWN AND CAN OUTPUT NEARLY 3000 VOLTS - 3500 VOLTS.
Step 4: BUILDING THE HIGH VOLTAGE TRANSFORMER
SO FIRST OF ALL I SEARCHED FOR A FERRITE CORE TRANSFORMER IN MY ARSENAL !! FOUND ONE AND STARTED THE PROCESS OF UNWINDING AND THEN SEPARATED THE CORE FROM ITS BOBBIN !!!
AFTER THAT WAS DONE I STARTED THE PROCESS OF WINDING A THE SECONDARY WHICH WOULD BE AROUND 1000 TURNS OR MORE OF 32 GAUGE ENAMLE COPPER WIRE !!!
WINDING PRIMARY IS BASICALLY ART IN ITSELF AND I HAVE EXPLAINED IT IN ONE OF MY PREVIOUS VIDEOS !!!
THE ONE I LINKED IN THE BEGINNING ABOUT THE PLASMA POWER SOURCE.
ONE SIDE NOTE : USE ELECTRICAL TAPE TO INSULATE THE WINDINGS AFTER EVERY 150 TURNS !!
Step 5: BUILDING THE VOLTAGE MULTIPLIER
AFTER THE POWER SOURCE WAS READY I STARTED BUILDINT THE VOLTAGE MULTIPLIER STEP BY STEP AND CHECKING THE ARCS AFTER EVERY STAGE .
Step 6: BUILDING THE ENCLOSURE
NOW FINALLY AFTER EVERYTHING WAS DONE IT WAS TIME TO BUILD THE ENCLOSURE . SO TOOK TWO PVC SHEETS DRILLED HOLES AT EACH CORNER . FIXED 4 INCH BOLTS ON EACH CORNER PLACED EVERYTHING INSIDE .
THEN SPARK GAPS WE MADE FROM SMALL IDENTICAL PIECES.
THEN MADE THE SPARK GAPS WITH SOME BOLTS SO THE DISTANCE CAN BE ADJUSTED !!!
Step 7: ENJOY THE ARCS AND SUBSCRIBE TO MY CHANNEL !!!
HOPE YOU LOVED IT !!!!
