Introduction: BYJ48 Stepper Motor
Stepper Motor is a motor controlled by a series of electromagnetic coils. The center shaft has a series of magnets mounted on it, and the coils surrounding the shaft are alternately given current or not, creating magnetic fields which repulse or attract the magnets on the shaft, causing the motor to rotate.
This design allows for very precious control of the motor,There are two basic types of stepper motors, unipolar steppers and bipolar steppers .
In This instructable , I will talk about an Unipolar Stepper Motor 28-BYJ48 .
The unipolar stepper motor has five or six wires and four coils (actually two coils divided by center connections on each coil). The center connections of the coils are tied together and used as the power connection. They are called unipolar steppers because power always comes in on this one pole.
Step 1: Specification , Motor Driver
There are many Types of Drivers , L293 , ULN2003 , A3967SLB , And More ,
The 28-BYJ48 Even comes with Breakout using ULN2003 As a Motor driver chip .
Specification for this Motor " And you can download datasheet from the attachment "
Rated voltage : 5VDC
Number of Phase 4
Speed Variation Ratio 1/64
Stride Angle 5.625° /64
Frequency 100Hz
DC resistance 50Ω±7%(25℃)
Idle In-traction Frequency > 600Hz
Idle Out-traction Frequency > 1000Hz
In-traction Torque >34.3mN.m(120Hz)
Self-positioning Torque >34.3mN.m
Friction torque 600-1200 gf.cm
Pull in torque 300 gf.cm
Insulation grade A
and the schematics of This breakout shown like the Pictures on the attachment
Note that if you want to use L293 Instead of ULN2003 , You will need to leave Red wire No connection .
Materials :
you will need :
1) Arduino Board .
2) BYJ48 Stepper Motor 5v
3) ULN2003 Moror driver Module
4) Jumper .
5) 5v voltage source "Optional" .
Step 2: Arduino Code .
But ...
You must take something in consider :
This Motor has a Gear ratio of 64 , and Stride Angle 5.625° so this motor has a 4096 Steps .
steps= (360°/5.625°)*64"Gear ratio" = 64 * 64 =4096 . this value will substitute it on The arduino Sketch
For adafruit Stepper Motor , the Stride Angle 7.5° and Gear ratio is 16 , So number of steps in 1 Revolution is :
steps= 48 * 16 = 768
That's will be different depend on what motor you are using , So check The Datasheet for Your stepper Motor to calibrate this values
28-BYJ48 Motor Datasheet .
Motor Driver ULN2003 BreakOut Connected To Arduino From IN1 - IN4 To D8 - D11 Respectively
To Power you Motor , Recommanded to use external Power Supply with 5V-500mA at least , Don't power it directly from arduino Board 5V .
Step 3: Library Direction Issue ... and How to Fix It .
step(steps);
So you must Put the Number of step to turn the motor .
The reference said You can put the positive value to turn one direction, negative to turn the other.
If that's OK With Your stepper Motor , You don't need to read the following .
If Not , Your Motor turn to same direction even you Put the steps Positive Value or negative , What is the issue ?
This Motor need to operate as the Table on the attachment .
the arduino Stepper Library need to modify to match this requirement .
I wrote a code which is allow to this motor to Move clockwise and counter clock wise
Code in the next step :
Step 4: Modify Code
BYJ48 Stepper motor code
Connect :
IN1 >> D8
IN2 >> D9
IN3 >> D10
IN4 >> D11
VCC ... 5V Prefer to use external 5V Source
Gnd
written By :Mohannad Rawashdeh
https://www.instructables.com/member/Mohannad+Rawashdeh/
28/9/2013
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
int Steps = 0;
boolean Direction = true;// gre
unsigned long last_time;
unsigned long currentMillis ;
int steps_left=4095;
long time;
void setup()
Serial.begin(115200);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
// delay(1000);
void loop()
while(steps_left>0){
currentMillis = micros();
if(currentMillis-last_time>=1000){
stepper(1);
time=time+micros()-last_time;
last_time=micros();
steps_left--;
Serial.println(time);
Serial.println("Wait...!");
delay(2000);
Direction=!Direction;
steps_left=4095;
void stepper(int xw){
for (int x=0;x<xw;x++){
switch(Steps){
case 0:
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
break;
case 1:
digitalWrite(IN3, HIGH);
break;
case 2:
digitalWrite(IN4, LOW);
break;
case 3:
digitalWrite(IN2, HIGH);
break;
case 4:
break;
case 5:
digitalWrite(IN1, HIGH);
break;
case 6:
break;
case 7:
break;
default:
break;
SetDirection();
void SetDirection(){
if(Direction==1){ Steps++;}
if(Direction==0){ Steps--; }
if(Steps>7){Steps=0;}
if(Steps<0){Steps=7; }
22 People Made This Project!
- Trevor_DIY made it!
- jkriener made it!
- PiotrW49 made it!
- b_o_cs made it!
- pieterg made it!
- boyarshome made it!
- 奕余 made it!
- BlaineS1 made it!
- adrianmvd made it!
See 13 More
116 Comments
Question 3 years ago
I would like to control 2 steppers with this code. Can I simply add 4 other digital pins for the other motor? It does not matter to me if they are synced up.
3 years ago
hello, if I want to make rotation only 90 degres, how the code ? thanks..
4 years ago
sir. I need an explanation about this Sketsh. especially the "time" that appears in the serial monitor and the explanation for "int xw" which I bold below
Connect :
IN1 >> D8
IN2 >> D9
IN3 >> D10
IN4 >> D11
Gnd
https://www.instructables.com/member/Mohannad+Rawa...
28/9/2013
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
int Steps = 0;
long time;
void setup()
delay(1000);
void loop()
stepper(1);
last_time=micros();
steps_left--;
delay(1000);
steps_left=4095;
switch(Steps){
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
default:
break;
SetDirection();
if(Direction==0){ Steps--;}
4 years ago
How can i change this code to use an analog sensor?
4 years ago
HELLO BRO, if i change 28byj 48 stepper motor form unipolar to bipolar then how can i find steps per rotation after modified, is it same or it changes to new value??? waiting for your answer bro
Question 4 years ago on Introduction
Hi.
You sayed "... To Power you Motor , Recommanded to use external Power Supply with 5V-500mA at least , Don't power it directly from arduino Board 5V ..." but in the photo attached to your article I don't see any external source. Why?
Answer 4 years ago
As m4biz sais it would be good to know why and when you need to connect with external power. Also an image of how to connect with external power would be nice to get started faster for people who are very new to the Arduino.
Reply 4 years ago
I too would appreciate an image and details of how to connect the power source, please!
Reply 4 years ago
I would also appreciate an image of how it is connected to an external source!
Answer 4 years ago
because in my case I ran the motor without load connected to the shaft so it will need a few milli amps to works
if you want to connect an external load to the shaft so you need to use external power supply
4 years ago
Excelente post, tengo un par por ahi; no sabia de cuantos pasos eran :)
gracias por tu magnifico post.
5 years ago
EXCELLENT POST !!!
I cut the code size down and modified it so you can specify Speed and don't need direction. Just call 'stepper()' and give it the number of steps you want to rotate. Use negative numbers to reverse the direction. You'll probably need to change the values for IN1-IN4 to match the pin numbers on your Arduino:
#define IN1 5
#define IN2 4
#define IN3 3
#define IN4 2
#define FULL_ROTATION 4076
const int phases1[] = {0, 0, 0, 0, 0, 1, 1, 1};
const int phases2[] = {0, 0, 0, 1, 1, 1, 0, 0};
const int phases3[] = {0, 1, 1, 1, 0, 0, 0, 0};
const int phases4[] = {1, 1, 0, 0, 0, 0, 0, 1};
int Phase = 0;
int Speed = 100; //MUST BE 1 - 100
void setup()
void loop()
stepper(FULL_ROTATION);
stepper(-FULL_ROTATION);
void stepper(int count)
int rotationDirection = count < 1 ? -1 : 1;
count *= rotationDirection;
for (int x = 0; x < count; x++)
digitalWrite(IN1, phases1[Phase]);
digitalWrite(IN2, phases2[Phase]);
digitalWrite(IN3, phases3[Phase]);
digitalWrite(IN4, phases4[Phase]);
IncrementPhase(rotationDirection);
delay(100/Speed);
void IncrementPhase(int rotationDirection)
Phase += 8;
Phase += rotationDirection;
Phase %= 8;
Reply 4 years ago
Thanks Curtis! This is lovely, elegant code, and it's now my go-to for stepper control -- works like a charm!
Reply 5 years ago
Good job mate!
4 years ago
Great Post! Great explanation - you helped me get a better understanding of fine control of unipolar steppers. Well done!
4 years ago
I need a stepping motor 28BYJ48 12VDC 1/32 NO.171029A. All I can find is one that's 5VDC 1/64
Question 5 years ago
I would be grateful if someone could help me, I have 2 of these motors and 2 drivers, I would like both motors to start clockwise 8 turns at 10 revs increasing to 18 revs for a further 8 turns and then the same in anti-clockwise and go back to start pause for 20 seconds and then repeat and so on.
Thank's in advance.
5 years ago
I want to run 24byj48 12v dc stepper motor at 100 pps then what is it's code....
5 years ago
Can I use 9v battery (external) to supply power for the motor via driver? Well, you said min 5v 0.5 amp, so I guess it's not a problem. Am I right?
Or is it better if I use 4 common 1.5 v batteries?
5 years ago
Hi guys, I want help from you, i need to made elevator with steppr motor j48 and control diraction with push buttons and to screen the number of etage in lcd so i need circuit diagram + code plaese if you can help me , im waiting you help
