Back Deck Pallet Chair
Intro: Back Deck Pallet Chair
I made this chair in a couple of hours and it has been a great addition to my back deck!
STEP 1: Pallets
It takes two pallets to make one chair. These are standard 4 foot pallets that I used.
STEP 2: Cut and Remove
Cut one of the pallets in half. (I used a circular saw)
Remove the middle board on each side of the cut pallet. (You will need these pieces later so try not to break them!)
STEP 3: Preparing the Seat
Cut the pallet in half. Then cut out you seat angle. I use a 26 degree angle (measured from a chair in my kitchen) you could use any angle you like.
The left side will be the seat and the right side, with the angle, will be the back.
STEP 4: Seat Assembly
Place the angled piece on the seat and use a long screw to hold in place.
Using a slat from the discarded half of the pallet (not the saved center pieces from earlier) insert it inside the seat for extra support. Cut the angle to match and then screw into place. Do this on both sides.
The seat is now complete! On to the arms!
STEP 5: Arm Prep
Cut the 2nd pallet in half.
Again remove the center slats to use for later!
STEP 6: More Arm Prep
Cut the pallet in half again. Each one of these will be the arms of the chair. Add your saved slats onto the end of the cut pallet. The left side has the piece added. The sides shown are the insides of the arms that you will attach the seat to.
STEP 7: Attaching the Arms
Place the seat onto the arm. Make sure the added slat is the back of the arm. I placed the seat 7.5 inches from the bottom of the arm and sticking out 2 inches in the front. Screw the seat to the arm.
The second picture is a close up of the overhang.
STEP 8: Finishing Touches
Attach the other arm to the other side.
Use the reserved slats to fill in some of the gaps on the seat and back.
Your chair can be done at the previous point but if you have extra 2x4's laying around you can fill the pallet gaps in the arms, seat, and back with them. Then sand the rough edges, seal or paint and add a cushion!
2 Comments
doodlecraft 9 years ago
Oh my, it's super cool! I love that it didn't take a ton of prep work! :)
Danger is my middle name 9 years ago
This is really nice! You should enter it in the pallet contest https://www.instructables.com/contest/pallet/
