Backing Up Your SQL Database Using XAMPP and PhpMyAdmin
Intro: Backing Up Your SQL Database Using XAMPP and PhpMyAdmin
I have just started to play with Joomla 1.5 content management system, to run a charity website, on a local host. One of the most important things to do is to work out how to back up the database so that I have something to fall back on just in case I mess it up.
These instructions are based on my own setup where the database is on a localhost on my own computer. Situations may be slightly different if the database is hosted elsewhere.
For this example we're looking at backing up a database named 'joomla15'.
IMPORTANT NOTE : Within the SQL structure it is possible to select databases, tables, or individual fields for editing, backup, deletion etc. These work instructions however are only concerned with backing up the WHOLE database. Unless you know what you're doing I would suggest you don't deviate from them as you can really screw things royally.
STEP 1: Step 1 - XAMPP Control Panel
Open the XAMPP control panel. If they are not already running you need to start the Apache and MySql modules.
STEP 2:
Login into phpMyAdmin. There are two ways to do this.
i.Click on the Admin button from XAMPP control panel.
ii.Type 'http://localhost/phpmyadmin' into the URL bar of a web browser.
You might need to enter a password for the root user.
Once in, the interface should look like this
STEP 3: PhpMyAdmin Interface
STEP 4: Database Selection
Now we need to select the database which needs backing up. This should be listed on the left side menu.
Take note of the number in ( ). In this case it is 45 which means that there are 45 tables contained within the database.
STEP 5: Database Tables
The interface should should change to be similar to this
On the left there is a list of all the tables contained within the database (green). On the right (main) part of the screen the tables are listed again with a set of possible actions for each one (blue).
WARNING: Unless you're really sure you know what you're doing, don't fiddle with anything here.
At the top of the screen are a set of tabs. Select the one marked 'Export'.
STEP 6: Export Main
The main part of the interface will bring up another screen which should look something like
STEP 7: Export 1
The main part of the screen is now divided into a number of sections.
i.Export
In this section you can specify which tables you'd like to backup. The default is for all of the tables but it doesn't hurt to select the 'Select All' link again.
i.Export
STEP 8: Export 2
Further down this section, it is possible to specify which type of file we'd like to create. Check that 'SQL' is selected. This means we're able to use this file for later restoring of the data is required.
STEP 9: Export Options
ii.Options
Leave as default settings.
STEP 10: File Structure
iii.Structure
We will select two extra check boxes, over and above the default.
STEP 11:
'Add DROP TABLE / VIEW / PROCEDURE / FUNCTION / EVENT' – this options adds extra entries in the SQL file. If the backup file is used to restore a database, these entries mean that tables etc. will be overwritten if they exist already, which means that you don't have to delete the tables beforehand.
The two images here show a before and after in the sql file, when using this option.
STEP 12: Add Into Comments
You can select any of these options if you wish as they shouldn't make any difference to the data from the database. They are simply used to put extra text into the file which maybe of use later.
STEP 13: Save As File
File name template is where you specify what the filename format should be. The default __DB__ will result in joomla15.sql (which is the name of the dbase in this work instruction).
Should you wish to include a date stamp to your backups you can use the following:
%Y%m%d%H%M%S-__DB__
which would result in something like
20100114144843-joomla15.sql
%Y%m%d%H%M%S-__DB__
STEP 14: Download !
When you click on the <GO> button in the bottom right of the screen, the browser should act as though it is downloading a file.
If you get a choice select where you want to save the file. If you don't get the chance you will need to select your default download location.
With WINDOWS this could be either the desktop or a directory under the 'My Documents'
10 Comments
TimH294 5 years ago
1. go to phpmyadmin => export => go and save the 127.0.0.1.sql file in the htdocs folder
You may need to edit php.ini to give a large value for the timeout so the task will complete in time
2. When that is done then select not just the htdocs folder but the entire xampp folder (the proper location for that is the root of your drive C: D: or whatever) and compress. That way you get all of your environment settings and the proper version of php ext. for the database to reload propery should you need to redeploy.
mikehomes 8 years ago
Specially designed to recovers damaged MDF File, NDF File and permits to export directly to SQL Server without creating any blank database.This software is supported all SQL Server version 2000, 2005, 2008, 2008 R2 and 2012.
Go through: http://www.filesrecoverytool.com/sql-database-repair.html
ErikLakatos90 9 years ago
U can check this link. Its very useful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
emallon1 9 years ago
You can efficiently restore the SQL database backup must
visit and learn more:- http://www.sqlrepairtool.org/sql-server-backup-restore-software.html
Go through this tutorial page:- http://www.sqlrepairtool.org/how-to-repair-sql.html
stone578 11 years ago
http://www.sqlrepair.sqlserverrepairtoolbox.com supports Windows 98/.../7 and any version of MS SQL Server application as well
vikrostiks 11 years ago
akrenvalk 11 years ago
You need to software recovering .sql databases of any version SQL Server.
I would recommend you to try tool below
sql server fix
mrmath 14 years ago
bunglesmate 14 years ago
