Introduction: Bacon Alarm Clock - Arduino
This is a project I came up with that was inspired by my love for bacon!
This is an alarm clock that is designed to wake you up with the smell of bacon. With the help of an arduino the alarm clock will already have the bacon aroma filling the room to wake you up before the alarm, or it will make you just want some bacon when the alarm goes off.
Step 1: Materials
1. Arduino Uno (can be found at Newark/Element 14)
2. RTC ( Real Time Clock ) shield with Bluetooth -( You will also need an Android device with the Blueterm app )
3. Mini Dual LED Matrix shield
4. Bacon scented oil
5. A 5" mini frying pan ( found at wal-mart )
6. Unscented candle wax
7. Oven bake clay ( for the bacon )
8. Sink strainer set
9. Electric Candle warmer
10. USB and AC receptical outlet combo - 120v / 15 amp ( Can be found online or at Home Depot )
11. 3~32VDC SSr-25 DA Solid State Relay ( Found online )
12. Wood to build your box
13. Plexiglass to build your display box
14. Spray Paint ( optional )
Step 2: Programming Your Arduino and Heating Pad
I used a sketch found in another instructable for the Silly Clock. This is also where I was able to order my shields for the arduino.
Links to Sketch and Parts:
http://timewitharduino.blogspot.com/2011/08/illycl…
https://www.instructables.com/id/Building-IllyClock…
I also attached the file for the updated sketch for this project below
Once I was able to get all of my parts for the Arduino and had the sketch uploaded, it was just a matter of tweaking the code. Because the RTC shield had bluetooth, I was able to control the clock wirelessly with the Android app Blueterm. This can only be done with an Android device and will not work with anything other. Once you have connected to your device via bluetooth, you can control your alarm with these commands:
ALARM TIME=00:00
TIME=00:00
ALARM ON
ALARM OFF
STOP ALARM
SHOW ALARM
The alarm clock is also set to show colors as: 3 hours before wake-up time, color changes from green to orange; 1 hour before wake-up, the time is shown in red.
Once you set your alarm time, the relay can be set in the sketch to switch on the heating pad before your alarm goes off. Once the alarm does go off, the relay will switch back to off and the heating pad will no longer be active.
Heating pad:
Next I took apart the Electric heating pad. The heating pad that I decided to use for my clock had an on/off switch which I decided to keep connected just to have the option of keeping it on or off regardless of the relay. I can also tell wether it is working or not by the small light that was attached to the switch. ( shown in the second and third photo ).
Step 3: Making the Bacon
What I did for this step was I found some bakeable clay that could withstand the heat from the pad and wax. Once I formed my bacon strips, I baked the clay as directed.
My next step was to melt my wax beads on the Electric candle warmer and add my bacon oil. Go with your judgment on how much oil to add.
This can also be a good time trial stage for you to find out just how long it will take the warmer to melt the wax and put off a good aroma. Once you find out how long it takes to do this, note the time to later put in the sketch.
Step 4: Wiring the Components
The first thing I did at this point, was check to make sure my relay was working. After taking apart my candle warmer and removing my heating pad, I hooked up my arduino and shields to the relay through an output that was attached to my RTC Shield ( output shown above in the first photo ).
Next you neet to supply your combo outlet which will go inside your box with a plug that can go from your clock to the wall plug. The outlet inside your box will supply both the Arduino and the heating pad. With the cord from the heating pad, you want the ground part of your cord running directly to the pad and the Positive wire going in one side of your relay. Then you connect a wire going from the other side of the relay to the positive side on your heating pad.
Once this is done correctly, you can connect your arduino with the usb cable to your outlet that will go inside your box and plug in your heating pad to the same outlet as well. ( shown in the second photo ).
Step 5: Build Your Box
My inspiration for the shape of my clock came from this little oven we have in our kitchen. Using the curves from the mini Iron oven, and the carpentry skills of my dad, we were able to build cut the wood to have that oven look. We build it just big enough to hold all of the components and to fit my mini skillet inside the display.
Once we had all the wood cut, we cut a hole the size of the sink washer and fitting to hold our heating pad. ( shown in photo 4 and 5). We used the sink fitting and washer to keep the pad from heating the wood and because it fit the size of the pad perfectly.
Next we cut a square for the display to fit in perfectly and attached a small strap over the Arduino and shields to hold it in place.
Once we had our box built and had all of our components fitting inside, I glued the sides of the box then used some brad nails for reinforcement.
After everything was enclosed, I taped my wire, display, and heating pad so that I was able to spray paint my box. The paint I used was a similar texture and color to the cast iron oven. Once this was dry, I peeled off all of the tape.
Step 6: Build Your Display
My next step was to build the display case to fit over the box. I bought a decent sized piece of plexiglass from home depot for around 20 dollars and a small plexiglass cutter and silicone. We measured the size the final box and used those measurements to size the display case. Once all of our sides were cut, we put holes in them using a drill. By adding the holes, the bacon aroma is able to fill the room.
The next step was gluing all of the sides of the display together using the silicone. I also used tape for reinforcement.
Step 7: Testing It Out
Once everything is build, you can use an android device to control your bacon clock. Here is the video of the finished clock!
First Prize in the
Arduino Contest
Full Spectrum Laser Contest
18 Comments
4 years ago
Hi! Do you have a different view or a step by step on how you wired the components? I'm just starting out and I'm having a hard time distinguishing which goes where.
5 years ago
Where do you get the BT RTC shield or is it custom?
Reply 5 years ago
here is the link from where I was able to order the shield from. I hope this helps! https://m.instructables.com/id/Building-IllyClock-an-alarm-clock-in-a-coffee-ca/
Reply 5 years ago
It was custom! I attached a link under step two! Hopefully this helps. Thanks for viewing!
6 years ago on Introduction
beautiful
rise & swine
Wake up to the smell of sizzling bacon.... :)
Great way to torture bacon lovers. It's diabolical. I like it.
Pure awesome!
Certainly better way to wake up than the anoying beeping from the alarm-clock I have :)
A critical component of morning bacon is the sound of it grilling. Should not be too hard to derive this effect from a white noise generator. Another bacon aficionado is comedian Jim Gaffigan. His love of bacon is another sound worth listening to.
Reply 6 years ago on Introduction
I was going to attempt that but I thought it would be too complicated for me to do with my deadline. This was for a digital multimedia class so I am still a rookie when it comes to electronics. I was also going to try to somehow incorporate a small computer fan, if possible, to really get the smell going. I may still try to keep improving on it even though the class is over. Thanks for the suggestions! :)
Too bad real bacon would spoil if it sat out overnight. It would have to involve some sort of refrigeration device to keep the bacon cold until the right time. Then you could wake up and eat the bacon.
This just means you have to get out of bed to go cook the real stuff. Mission accomplished ;)
Congratulations, You were featured in the week newsletter!
Thanks!! :)
6 years ago
Probably the best alarm clock since the Rooster! You got my vote!
Haha! Thanks!
6 years ago
Obviously somewhat inspired by the Office episode where Michael Scott burns his foot on the Foreman grill attempting to cook bacon as a wake up alarm in the morning, lol.
Great job with the project!
