Introduction: Bacon Roasted Almonds
Why not mix almonds with one of the best ingredients from nature Bacon
Step 1: Ingredients
For this instuctable you will need
500g almonds
150g Bacon (not enough)
1 tablespoon coarse salt
2 dl water
500g almonds
2 dl water
Step 2: Dry the Almonds and Prepare the Bacon
Put the almonds in the oven at around 300°F (150°C)
The drying time varies and the almonds should be watched.
Check the almonds until the desired crunchyness is reached
I used a microwave to roast the bacon
Prepare a microwave bowl to the roasting by brushing the rims with oil
Hang the bacon on the sides of the bowl and put the bowl in the microwave for about 10 minutes.
Keep and eye on the bacon as it must not to burned.
The time will vary according to the microwave you own.
Step 3: Blend the Bacon
When the bacon is ready the next step can start.
The bacon is mixed with the salt and blended to a pulp.
Step 4: Mix the Ingredients
Add the ingrdients to a pan and heat up the mixture
Heat up the mixture until the buttom of the pan is visible
Step 5: Add the Dryed Almonds
Add the dried almonds to the mixture while stiring
when the pan is dry the almonds are ready
Step 6: Dry the Almonds Again
When the almonds are ready put them on a pam and put them in the oven again.
The oven must be set to 300°F(150°C)
This time it is very important to watch the almonds as the must not get to much
The roasting time must be watched.
The time will vary, which mean that you must watch them and stir ofte
Step 7: Bacon Almonds
When the almonds are done put them in a bowl.
Remember to make plenty of almonds because they can be gone quickly.
Make the almonds your own by changing ingredient and share on instructable
My experience with these almonds it that the amount of bacon wasnt enough.
The taste that was added to the almonds was a bit on the weak side.
