Introduction: Balancing Instructable Robot
In this Instructable I wanted to show to you how to make a self balancing robot. What makes it unique is that its exterior is made to look like the Instructables Robot. Internally it works in the principle of PID, it is a very popular control system for maintaining a variable from fluctuating. In this instructable I have used the MPU6050 which is a gyroscope and an accelerometer in a single package. The gyroscope is used to find the angular orientation and the acceleration. For our application we just need the gyroscope data. To start off I will discuss the various applications and knowledge obtained from this project. Please vote for my entry in the "Instructable Robot Contest" if you find this instructable good.
Project-Based Learnings:
Knowledge of how to use the MPU6050 module.
How to implement the data to balance the robot.
How to implement control systems to your projects.
____________________________________________
Applications:
This Instructable serves as an introduction to the various Control Systems.
These Control Systems are also implemented in Segways and The Ball Balancing Robot.
These Control Systems are also applied to PID Furnace Temperature Control, The Line Following Robot, etc.
Proportional-Integral-Derivative System Advantages:
This Control System should be used when the controlled element needs precise control.
This balancing robot can be easily made by a Novice Arduino Programmer using this Control System.
- The tuned PID system is very flexible over a range of environments (i.e. balancing even when weight is added).
This control system's efficiency depends on the tuning of three variables namely the Proportional constant, Integral constant and Derivative constant, So once you tune the variables accurate control of the robot is achieved. I have provided most of the instructions for making the robot. This robot is in the intermediate level of robotics so beginners shouldn't get frustrated because it for very challenging for Me!!!
Step 1: Parts & Materials
The material needed to make this balancing robot can be grouped into two categories as shown below:
Electronic Components:
Other Parts:
Please note that I have not used Acrylic Sheet as mentioned but Hylam Sheet(Bakelite Sheet). It is very much similar to acrylic but more rigid and easier to cut. It is commonly used in India for Switchboard Boxes. It may or may not be available in your Country so I mentioned it as an Acrylic Sheet.
Step 2: Making the Robot Chassis
This step is for making the chassis parts which form the base of the robot. As I mentioned earlier I have not used the acrylic sheet but a Hylam Sheet. The base consists of two strips to which the motor is mounted and a rectangular base on which these strips are mounted in perpendicular. To prepare the Body follow these instructions.
In this Step, I cut the strips that support the motors. I've cut them with dimensions of 2cm by 8cm. This material is much stronger than the acrylic sheet.
When the sketch has been drawn, cut the pieces out using a Hacksaw or a Jigsaw cutter. The cutting process will produce a lot of dust. Cut the sheet in a well ventilated room.
Next comes the base which supports the two strips. Draw a Rectangle of about 14cm in width and 18cm in length. Then draw the mid-line for the base along the width as shown in the diagram. This line will serve as a guide line for fitting the strips.
Cut out this drawn part using the Hacksaw or the Jigsaw cutter as shown. Use a marker for reference and clean the board later to remove the marker lines.
Next draw two vertical lines as shown in the diagram. These lines are used for aligning the clamps of the motor. With this step we have finally completed the chassis components. The next step deals with the motor and wheel assembly.
Step 3: Attaching the Motors
After cutting the chassis components next comes, assembling the motors with the strips we cut earlier, then attaching these strips to the bigger piece we cut using L-clamps. The motors need holes for the wires to pass through so they should also be cut in addition to the clamp holes.
Cut some double sided tape and stick it to one end of the strip as shown in the diagram. This method involves no clamping with nuts and bolts.
Remove the double sided tape top paper cover to reveal the other adhesive side of the tape. Place the motor on the tape so that it is parallel to the strip.
Then tighten the motor to the strip using cable ties. This ensure that the motor is firmly clamped to the strip.
Cut off the excess and Cable tie wire using either a wire stripper or scissors.
Fit the wheel into the motor and tighten the joint using a screw as shown.
There you go you have completed mounting the motor onto the strip. Repeat the procedure for the second strip and you would have obtained two of the Instructable strong>Robot's legs with wheels. The final diagram shows the completed legs.
Step 4: Finishing the Chassis
With this page we will complete the chassis of the Instructable Robot. The prepared chassis is very rigid and stable and is capable of handling the weight of the battery and the electronics. The motors in the pictures are dirty, please excuse it since I have been using them for my other projects.
In this step I use a L-Clamp which is basically a piece I have in my childhood engineering set. You will be easily able to find out L-Clamps, a link to some clamps is also provided. Anyway place the clamp on top of the free end of the strip. Then mark the holes of the clamp using a marker.
Repeat the same procedure for the other motor strip. You will obtain two strips with holes marked and ready for drilling.
This step shows Me drilling the holes on both the motor strips. The holes are made by a 4mm drill-bit.
Before mounting the clamps on the strips, place the clamps on the main board as shown in the diagram. Then mark the holes using a marker for drilling.
This step shows Me drilling the holes on the base of the chassis.
I only drilled two holes in the previous picture but another hole is needed for the wires to pass through the chassis. So please make another hole.
On completing all these steps you will obtain the following assembled parts as shown in the diagram.
I have not provided any pictures of tightening the nuts and bots but once screwed in, it will look as shown in the diagram.
After completing all these steps the finished chassis will look as shown in the last Figure. The chassis houses the Battery, Ultrasonic Sensors and The Electronics.This ends the mechanical work needed for this project.
Step 5: Mounting the Motors to the Driver.
Lets move on to wiring the electronics for the robot. The next few steps will have some Fritzing sketches, some additional images and a little description of the module we are using. So that you are aware of both the working and how to operate the module. The steps below show us how to wire the motors and fix the battery.
In this step I solder the wires to the motor terminals.
Pass the wires through the extra hole we drilled in the clamp as shown in the figure.
Place the module on the base and mark the holes using a marker.
In this step I make the using using a 4mm Drill bit.
Fix the module to the base using some nuts and bolts. This firmly fixes the module to the base.
Connect the motors to the motor terminals of the module and the 9V battery connector to the Power terminals of the Module.
Finally screw the terminals using a Screw-driver so that the wires are fixed.
Step 6: Mounting the Arduino
This involves mounting the Gyroscope sensor module and the Arduino UNO board to the base of the robot.
Firstly mark the holes for the Arduino module on the base using a marker.
Drill the holes using the same 4mm Drill bit. For the Arduino three holes are enough for mounting to the base.
This steps shows the holes drilled onto the base of the robot. Please ignore the extra holes they are from my previous incorrect mounting attempts.
Finally screw the Arduino to the base using some screws as shown in the figure.
Place the Gyroscope module on the base and mark the holes using the marker.
Drill the holes and mount the module as shown in the diagram. I have also provided a side view of the module mounted to the base. The more elevated the module the better so use long screws as shown.
This concludes the mounting of the motor driver module, the gyroscope and the Arduino UNO. I have provided the motor driver wiring diagram please use this diagram. Connect the respective pins using the jumper wires I couldn't show the steps for that but I think I have provided enough images. The final image shows the chassis with the motor driver board and the battery attached.
Step 7: Increase the Arduino Power Pins
Power Pin Expander:
Since this project involves a lot of power pins. I had to make a power pin expander. This is not my own idea but I got it from another Instructable.Check out the maker of this idea "Arduino Micro Power Expansion Shield" by Wenzej. Anyway I have added a mini Instructable for expanding the Power pins of the Arduino.
Parts Needed:
Making The Expander:
First solder the 4-Pin Connector as shown in the diagram.
Remove the plastic of the 4-Pin Connector. This needs to be done carefully as the metal headers may break off.
Insert the female header strips into the strip board as shown in the diagram.
Solder the Power rails as shown in the diagram.
Then you are done. The final image shows the finished module and the other image shows the module inserted into the Arduino UNO power pins.
Step 8: Inserting the Potentiometers
Why I used Tuning Pots:
As you know this project uses PID Control. So we need to set the values of the proportional, derivative and integral constant. So I made this easy way with which the values can be set easily. Basically I use potentiometers and the analog pins of the Arduino to set the value. The potentiometer gives us a value of 0V to 5V which is then converted into values from 0 to 255. The following code is responsible for this conversion.
Kp = map(analogRead(A0), 0, 1024, 0, 200); Ki = map(analogRead(A1), 0, 1024, 0, 20); Kd = map(analogRead(A2), 0, 1024, 0, 20);
So using the map command you can set the values with just the turn of the potentiometer you can dynamically set the values for the constants. This saves you the hassle of changing the values of the constants in the code and reprogramming them repetitively. I have included a Fritzing sketch of the circuit for the potentiometers.
Assembling the Tuning Pots:
Mark the holes where the potentiometers need to be inserted using a marker.
Drill holes in the marked base using a 12mm drill bit.
Before we insert the potentiometer. We need to make holes for the extra flange coming out from the potentiometer. The use of this flange is to prevent the potentiometer from rotating. Mark the flange location with a marker.
Make 2mm drills in these spots for the potentiometer flanges.
Inset the potentiometers into the holes and finally tighten the nut in the potentiometer to affix it to the bottom side of the base.
Fix the knobs into the potentiometer shafts to give it a more aesthetic look.
Wire up the power pins to both ends of the potentiometers as shown in the diagram.
Finally wire the Wiper pin (middle pin) to the analog pins of the Arduino. The final diagram shows the completed wired module.
I have also provided a sample code to test the potentiometer to check they are working properly. Wire the circuit as shown in the fritzing sketch and you will be able to adjust the PID constants and the serial monitor will show the constant values. If all goes well you will obtain an output similar to the final image.
Step 9: Connecting the Motor Driver
Introduction to the L298:
The motor driver I have used for this project uses the L298 Dual H-Bridge Motor Driver. The reason I chose this board was its advantages over other drivers. The L298 IC has an amperage of 2A. Another Reason is that I have burnt quite a few L293 Motor drivers because of its low Ampere capacity. Lets start off with the pins of the L298 Board.
The L298 Board Pins:
Enable Pin (ENA and ENB): This pin needs to be set to HIGH or the board won't process the command given through the other pins. So this pin permits the IC to receive commands from the Arduino when it is turned HIGH.
Current Sense Pin (CSA and CSB): The current sense pins in general can be tied to ground, but one can
insert low value resistor, whose voltage reading is proportional to current. Here we just tie them to ground. Note that your board may or may not contain this pin, if it doesn't just forget about this pin.
Input Pins (IN1,IN2, IN3 and IN4): As the name suggests these pins go to the Arduino. Where IN1 and IN2 belong to Channel A and IN3 and IN4 belong to Channel B. The truth table for operating two motors are as follows.
Motor A | Motor B | ||||||
IN1 | IN2 | OUTPUT | IN3 | IN4 | OUTPUT | ||
1 | 0 | FORWARD | 1 | 0 | FORWARD | ||
0 | 1 | REVERSE | 0 | 1 | REVERSE | ||
0 | 0 | STOP | 0 | 0 | STOP |
That concludes my introduction to the l298 motor driver board. This board can be bought in this link or it can be made, I haven't done a tutorial on how to make your own maybe soon. I have provided a Wiring diagram for connecting the L298 to the Arduino.The final diagram shows the connected jumper wires on the base of the robot.
Since both the motors are driven in the same direction we connect it to the same analog pin of the Arduino. Since the Arduino only contains six analog pins, the motors are driven by the same pin.
Step 10: Connecting the MPU6050
About the MPU6050:
The MPU6050 is one of the best and cheapest accelerometer and gyroscope modules you can get out there. The functions performed for the prices is just outstanding.The module has on-board Digital Motion Processor™ (DMP™) capable of processing complex 9-axis Motion-Fusion algorithms. The variable that are required for this project are just the yaw, pitch and roll, they are used to describe the rotations occurring along the three axises of the robot.
The MPU6050 can be purchased for cheap in this link. I have also provided a Fritzing Sketch for connecting the MPU6050. I have provided an example code with which the MPU6050 can be tested. The Final image shows the MPU6050 wired to the Arduino in the robot.
MPU6050 Important Pins:
Power Pin (Vcc):
Used to supply positive voltage to the MPU6050 module.
Ground Pin (GND):
Connects to the ground pin of the Arduino.
SDA & SCL Pins:
Used to establish a connection with the Arduino analog pins A4 and A5 to receive the accelerometer and gyroscope data.
Interrupt Pin (INT):
This pin instructs the Arduino when to read the data from the module, this pin instructs the Arduino only when the values change.
I have provided a small code to test the module before entering the main code. This code is made by Jeff Rowberg So just include the library using the following steps:
Loading the Library:
- So open the Arduino IDE software.
- Go to Sketch => Import Library => Add Library.
- Select the downloaded library which I have named "i2cdevlibmaster" and click ok.
- Now that the library is loaded go to File => Examples => i2cdevlibmaster => Arduino => MPU6050 => Examples => MPU6050_DMP6.
- Just compile the sketch and upload it to test the MPU6050 Module.
- If everything goes well you will obtain the same output as the final image.
Step 11: Finishing Touches
We have almost finished the business end of the robot. These steps summarize the power supply for the boards.
Put some double side tape on the base as shown in the diagram. Its more simpler than bolting the batteries to the base.
Stick the batteries onto the double sided tape. Insert the 9V power connector into the Arduino board.
Insert the power connectors on both the 9V batteries and the power is supplied to all the modules.
The next step contains the code as well as additional details used to make the robot. Just upload the code into the Arduino and connect the power supplies to the respective boards. After some tuning of the PID constants you can obtain great results. I have provided a video in the next step.
Step 12: Uploading the Code
Once you have made the robot finally its time to upload the code and give the robot a test run. I have provided the completed code just upload it and experiment with the PID constant to achieve proper balancing.
CODE:
#include "I2Cdev.h" #include "MPU6050_6Axis_MotionApps20.h" //#include "MPU6050.h" // not necessary if using MotionApps include file // Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation // is used in I2Cdev.h #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE #include "Wire.h" #endif MPU6050 mpu; #define OUTPUT_READABLE_YAWPITCHROLL bool dmpReady = false; // set true if DMP init was successful uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU uint8_t devStatus; // return status after each device operation (0 = success, !0 = error) uint16_t packetSize; // expected DMP packet size (default is 42 bytes) uint16_t fifoCount; // count of all bytes currently in FIFO uint8_t fifoBuffer[64]; // FIFO storage buffer // orientation/motion vars Quaternion q; // [w, x, y, z] quaternion container VectorInt16 aa; // [x, y, z] accel sensor measurements VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements VectorFloat gravity; // [x, y, z] gravity vector float euler[3]; // [psi, theta, phi] Euler angle container float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector static int pot1Pin = A0; static int pot2Pin = A1; static int pot3Pin = A2; float Kp = 0; float Ki = 0; float Kd = 0; float targetAngle = 8.5; float currAngle = 0; float pTerm = 0; float iTerm = 0; float dTerm = 0; float integrated_error = 0; float last_error = 0; float K = 1; // ================================================================ // === INTERRUPT DETECTION ROUTINE === // ================================================================ volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high void dmpDataReady() { mpuInterrupt = true; } // ================================================================ // === INITIAL SETUP === // ================================================================ void setup() { // join I2C bus (I2Cdev library doesn't do this automatically) #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE Wire.begin(); TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz) #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE Fastwire::setup(400, true); #endif Serial.begin(115200); while (!Serial); Serial.println(F("Initializing I2C devices...")); mpu.initialize(); Serial.println(F("Testing device connections...")); Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed")); Serial.println(F("Initializing DMP...")); devStatus = mpu.dmpInitialize(); mpu.setXGyroOffset(220); mpu.setYGyroOffset(76); mpu.setZGyroOffset(-85); mpu.setZAccelOffset(1788); // 1688 factory default for my test chip if (devStatus == 0) { Serial.println(F("Enabling DMP...")); mpu.setDMPEnabled(true); Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)...")); attachInterrupt(0, dmpDataReady, RISING); mpuIntStatus = mpu.getIntStatus(); Serial.println(F("DMP ready! Waiting for first interrupt...")); dmpReady = true; packetSize = mpu.dmpGetFIFOPacketSize(); } else { Serial.print(F("DMP Initialization failed (code ")); Serial.print(devStatus); Serial.println(F(")")); } pinMode(3, OUTPUT); pinMode(4, OUTPUT); pinMode(pot3Pin, INPUT); pinMode(pot1Pin, INPUT); pinMode(pot2Pin, INPUT); pinMode(A3, OUTPUT); pinMode(12,OUTPUT); pinMode(13,OUTPUT); } // ================================================================ // === MAIN PROGRAM LOOP === // ================================================================ void loop() { if (!dmpReady) return; while (!mpuInterrupt && fifoCount < packetSize) { } mpuInterrupt = false; mpuIntStatus = mpu.getIntStatus(); fifoCount = mpu.getFIFOCount(); if ((mpuIntStatus & 0x10) || fifoCount == 1024) { mpu.resetFIFO(); Serial.println(F("FIFO overflow!")); } else if (mpuIntStatus & 0x02) { while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount(); mpu.getFIFOBytes(fifoBuffer, packetSize); fifoCount -= packetSize; #ifdef OUTPUT_READABLE_YAWPITCHROLL mpu.dmpGetQuaternion(&q, fifoBuffer); mpu.dmpGetGravity(&gravity, &q); mpu.dmpGetYawPitchRoll(ypr, &q, &gravity); Serial.print("ypr\t"); Serial.print(ypr[0] * 180/M_PI); Serial.print("\t"); Serial.print(ypr[1] * 180/M_PI); Serial.print("\t"); Serial.println(ypr[2] * 180/M_PI); #endif Kp = map(analogRead(pot1Pin), 0, 1024, 0, 255); Ki = map(analogRead(pot2Pin), 0, 1024, 0, 20); Kd = map(analogRead(pot3Pin), 0, 1024, 0, 20); Serial.print("Kp: "); Serial.print(Kp); Serial.print(" Ki: "); Serial.print(Ki); Serial.print(" Kd: "); Serial.println(Kd); currAngle = (ypr[1] * 180/M_PI); Drive_Motor(updateSpeed()); Serial.print("speed: "); Serial.println(updateSpeed()); } } float updateSpeed() { float error = targetAngle - currAngle; pTerm = Kp * error; integrated_error += error; iTerm = Ki * constrain(integrated_error, -50, 50); dTerm = Kd * (error - last_error); last_error = error; return -constrain(K*(pTerm + iTerm + dTerm), -255, 255); } float Drive_Motor(float torque) { Serial.print("torque: "); Serial.println(torque); if (torque >= 0) { // drive motors forward digitalWrite(3, LOW); digitalWrite(4, HIGH); digitalWrite(12, LOW); digitalWrite(13, HIGH); } else { // drive motors backward digitalWrite(3, HIGH); digitalWrite(4, LOW); digitalWrite(12, HIGH); digitalWrite(13, LOW); torque = abs(torque); } analogWrite(A3,torque); }
If the connections are exactly followed you will get the motors turning in at least one direction, if it doesn't go back to the previous steps and check the connections again. When all goes well you will obtain results as shown in the Test Video above. Next I will give some instructions on how to get decent results from the PID constants.
Tuning the PID Constants:
- Firstly increase the proportional value by slowly turning the proportional potentiometer knob. Test the balancing of the robot for every turn of the potentiometer.
- Then when the robot oscillates from side to side like a pendulum then you increase the Integral and Derivative constant potentiometers.
- This is the most difficult part because only at certain values can effective balancing be achieved in the robot. My suggestion would be to vary the values and determining the ideal values for your robot. Please note that these values vary from robot to robot.
Please note that this is my first successful balancing robot. So I have got the robot balancing but there surely is room for improvement. In the future I want to make a more precise PID controlled balancing robot with additional features maybe in the future.
Step 13: Cutting the Body
As you know already the base of my robot is about 17 by 12.5cms so cut the parts as given in the pictures provided.
Cut the first image into two separate sides. Please note that one side is the mirror image of the other side. After this step you will have two cut pieces.
Cut the second image to the dimensions provided. This piece will serve as the back of the Instructable robot.
Finally cut the the third image which serves as the front and the top of the robot.
Cut the individual pieces out with scissors.
Place the cut pieces as shown in the figure and tape the pieces up using clear tape.
Place the other mirror image of the first cut piece like as shown in the figure and tape it up.
Finally tape the front piece and you are done with the body sides.
Fold up the pieces into a square, tape the final side into a box. tape all the sides to make it rigid.
Fold the top flap to make the top base. Stick another rectangle of dimensions 8.5 to 17 cm and stick it to the top of the robot.
Cut up six sides of squares of 10 cm and tape them up to form a box.
Put some double sided tape on top of the base and stick the prepared head into the base.
Finally draw the robots features using the sketches to finish the robot and stick two toothpicks on two sides of the head.
Make two yellow cylinders to cover the robots motors and constitute the legs of the robot.
Stick the robot cardboard body to the mechanical base of the robot using some clear tape and then you are done.
Open the robot up, turn on the power supply, close up the robot and see your balancing robot in action.
Step 14: You're Done!!!!!
Finally we have reached the end of this project. Personally I had to face many difficulties to complete this project but after I completed first Balancing robot I felt it was all worth it. I have learn't a lot from this project and I hope you have as well. I have provided a video showing the final performance of the robot. I look forward to my next instructable. If you have any comments or suggestions about the project please do ask. If you find this project good please vote for my project. Till next time Bye!!
Instructables Robot Contest
25 Comments
3 years ago
For last two days I have been trying to understand the wire connections showed by you, but could not understand. In the description you have mentioned that the PIN connections from Motor driver to Arduino should be: IN 1 to 5, IN 2 to 7, IN 3 to 10 and PIN 4 to 12 and in the CODe it is PIN No. 3,4,12 and 13 respectively. I am confused. In short what I have done is like this: Motor Driver pin IN1, IN2, IN3 and IN4 connected to Arduino's PIN 3,4,12 and 13.Moreover, The Enable A and B (both) PINs I have connected to Analog pin A3. My Bot is not getting activated except I can see the PID values through Serial Monitor. I have set the values like: kp= 105.00, ki= 12.00 and kd= 5.00. Are these values the targeted values or I am supposed to redo something else.I saw lot of photos of the wiring, at different- different stages and got confused. Can you spare for me a total (final) wiring diagram so that I can complete the project.
6 years ago on Introduction
Wow, amazing and such detailed instructions! Nice work! :)
Reply 6 years ago on Introduction
Thank you!
Reply 5 years ago
hey, which library we have to download.?? i got error so pls rply thanks
5 years ago on Introduction
Hi. The robot does not work for me.
The motor turns only in one direction
i need help please . when i make the power of the driver l298 the sensor blocked and don't return any value
hi
i am done with all the connections and code but when by robot lean to forward than its left wheel moves forward and when it lean towards back than its right wheel turns backward can you please tell me the solution of it
5 years ago on Step 14
Didn't work very well!
Can you please explain why you " targetAngle = 8.5 " rather than " 0 " cause I'm facing the problem I can't stop motors at just Vertical position rather they stop on slightly bent angle.
how to apply complementary filter using this code?
Now this is how you fukin explain a project. !!JObWeldon
sir...beautiful robot...
is robot ko modify karke....24 volt ki brushlss motor lagakar....nd 20-24 amp ka motor driver use kake segway bana sakte h....????
and india me sabertooth motor driver jo 24 amp ka hai availble nahi hai.....plzzz mjhe suggest kijiye ki kese ek rideable segway banaya jaye with the help of your robot....
5 years ago
great work .. some useful tips I've observed while making these is that your IMU must be as close to the axis of rotation as possible. Also like an inverted pendulum ..its more stable when the weight is distributed at the top rather than lower towards the base .. moving things around might just work.
Great work. In my version based on yours I found it necessary to put a pot on to trim out the gyro bias. This stops it trying to move forwards or backwards all the time and stand still!
6 years ago on Step 10
Hello.
Great Robot!
I am new to Arduino so I hope you can help.
When I compile the MPU6050_DMP6.ino I receive the following errors.
Arduino: 1.5.7 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from MPU6050_DMP6.ino:48:0:
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:89:7: error: 'prog_uchar' does not name a type
const prog_uchar dmpMemory[MPU6050_DMP_CODE_SIZE] PROGMEM = {
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:229:7: error: 'prog_uchar' does not name a type
const prog_uchar dmpConfig[MPU6050_DMP_CONFIG_SIZE] PROGMEM = {
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:271:7: error: 'prog_uchar' does not name a type
const prog_uchar dmpUpdates[MPU6050_DMP_UPDATES_SIZE] PROGMEM = {
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpInitialize()':
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:342:30: error: 'dmpMemory' was not declared in this scope
if (writeProgMemoryBlock(dmpMemory, MPU6050_DMP_CODE_SIZE)) {
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:349:42: error: 'dmpConfig' was not declared in this scope
if (writeProgDMPConfigurationSet(dmpConfig, MPU6050_DMP_CONFIG_SIZE)) {
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from C:\Program Files (x86)\Arduino\libraries\I2Cdev/I2Cdev.h:77,
from MPU6050_DMP6.ino:46:
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:390:98: error: 'dmpUpdates' was not declared in this scope
for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:394:98: error: 'dmpUpdates' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:433:98: error: 'dmpUpdates' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:437:98: error: 'dmpUpdates' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:441:98: error: 'dmpUpdates' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:459:98: error: 'dmpUpdates' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:478:98: error: 'dmpUpdates' was not declared in this scope
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Thanks
Ralph
I'm sorry I didn't reply sooner!! this is very complicated to find the problem I just suggest to start over with each individual module tested using the serial monitor to check the output from the accelerometer!!!
Great works! I have made one too!
The only problem is that my motors just vibrating back and forth irregularly.
Can you help me to solve this problem?
I noticed that my motors work on 90 rpm. And maybe it is noisy, as camiano said.
I have sent you a PM with my troubleshooting tips!!!
Frustating afternoon adding motors to my working electronics. Immediately on start up - the motors just went into full throttle in one direction. Tilting the machine back and forth had no effect. I tried separating the arduino/shield power supplies and added smoothing capacitors to each motor - no change. Tried it with just one motor - no change. Finally I swapped the motors for another similar set. SUCCESS! Seems like the new motors I bought for this project are very very noisy.
Great you found the problem I almost went crazy trying to produce results for my robot :) , post the pic of the finished robot!!!!
