Ballistics Gel
Intro: Ballistics Gel
This is a cheap and easy way to make ballistics gel easily
The Mythbusters use this stuff all the time
I got this idea from mythbusters and i see them use it all the time on the show so I wanted to make some
STEP 1: What You Need
- Unflavored gelitan packets
- Measuring cups
- Measuring bowl
- Spoon
- Tupperware container
- Measuring cups
- Measuring bowl
- Spoon
STEP 2: Step 1
measure out 2 cups of warm water
you need to add 2 gelatin packets for every cup of water
STEP 3: Step 2
Slowly mix in the 4 packets of gelatin with the 2 cups of water
make sure you are stirring the water as you are adding the gelatin
if you don't the gelatin will clump up
STEP 4: Step 3
Add your mix into your Tupperware container then
freeze it for a half an hour
let it sit in room temp for 10 minutes
then refrigerate it for 30 minutes
then freeze it again for 12 - 14 hours
STEP 5: Finished
It should look like this when you're done
I love to make this stuff I test my knives and airsoft guns on this
If you liked this project follow me on instructables to get notice of when I come out wit my new projects
Thanks
Please check out my other instructables
Thanks
70 Comments
STF 11 years ago
Nick-Smith-513 11 years ago
STF 11 years ago
Like this http://longrangeshooter.com/wp-content/uploads/2008/06/ballistic-gel.thumbnail.jpg
JonathanL20 8 years ago
I would try using HOTwater like scalding hot water
STF 8 years ago
Talk about comments back from the dead! LOL Thanks,
DamascusSword247 3 years ago
dad_a_monk 11 years ago
Now Smitty's gel is just five for things like looking at knife impact but it would never be regulation density even adding more gelatin powder. To get exactly 10% by weight and a stable gel it take a much more methodical scientific approach .
Again many people only have things like Mythbusters as a source and they never show all the steps or tell you how long it takes to cure. So people see them pour powder in a bucket stir it with a drill paint stirer and pour it in a mold and proof its ready to use. It is just NOT that simple.
What you have here and in many guides is basicly the Jello Jigglers recipe that just makes dense gel but usually too dense and not stable enough.
There is still a good use for this type of gel but it will not show you proper penetration. He said he uses it for testing knives and -airsoft guns, I'm sure its great for that.
Epicgamerz 11 years ago
Snipekill98 8 years ago
to get the gel to be the closest to fbi standards you need to add 1 oz of gelatin to 1 cup of cold water then mix it until there are no chunks then heat it on a stove at about 130 degrees until it is in a liquid state it should be like water. then you have to refridgerate for 3-4 hours then re heat and refridgerate for 12-24 hours i make it this way all the time and it always turns out perfect every time.
btrog 9 years ago
If i am not use it right away after 14 hours do i refridgerate it or what?
btrog 9 years ago
what should i do mine is frozen solid?
jack 8 years old 9 years ago
razzakbane 10 years ago
SKATERPRO 10 years ago
sprnklz54 10 years ago
TREX ZoaR0K 10 years ago
pcanywii 11 years ago
