Introduction: Balloon Fin Lamp
This is a 3d printed lamp that looks like a balloon.
The lamp has a fin design that creates light and shadow affect.
There are holes in the top of the balloon that allow little shapes of light to project onto the ceiling.
The lamp is printed in three parts; the lampshade, the lamp lower and the cell triple base (so called as it holds three LED stars).
The lamp requires some soldering and a little assembly
Step 1: 3D Print the Lamp Parts
There are three STL files (attached) that need to be printed.
I print the lamp lower and the cell triple base together, these take about 4 hours
I print the lampshade separately with a brim this takes about 12 hours
So far I have printed this lamp in PLA
Step 2: Bill of Materials
In addition to the 3D printed parts the following items are needed
It requires the following components.
Three 1W watt LEDs
Three heat sink LED stars
Thermal adhesive to attach the LEDs to the heat sinks
A SPST toggle switch
A 12v 1000ma power supply
A power socket to match the power supply
Three M3 screws
A 2W 10 Ohm ballast resistor ( you may need a different value based on your LEDs
You can calculate the value of the resistor using the website below
Step 3: Attach the LEDs to the Heat Sink Stars
You can buy preassembled LED stars or you can buy the LED's separately and attach them to the stars.
If you are attaching your own LEDs to the heat sink, you can either use surface mount paste and a reflow oven. Alternatively I used some thermal adhesive compound to connect the LED to the star and then soldered the leads to the pads.
Ensure you orient the LEDs the same way round on each pad, I used a multimeter with a diode check function to make sure they were all wired the same way.
Once you factor in the thermal adhesive, you are not really saving much money assembling your own stars, unless you are making a number of lamps.
Step 4: Wire the Stars in Series in the Triple Cell Base
Once you have three stars wired with LEDs, you need to wire the three pads in series into the triple cell base.
Pre solder a positive and negative pad on each star, then place each star into the triple cell base.
Cut some short lengths of wire to connect the pads and solder the positive of one cell to the negative of the next. Only do this connecting each one to the next, do connect the last pad back to the first.
Add a longer positive wire to the first pad and a longer negative wire to the last pad.
Pass these wires through the central hole in the triple cell base through to the under side.
Step 5: Wire the Switch, Ballast and Socket
Solder the positive terminal of power socket to one terminal of the toggle switch.
Solder the negative terminal of the power socket to the ballast resistor
use heat shrink to insulate the connections
Solder the positive from the LEDs to the other terminal of the toggle switch
Solder the negative from the LEDs to the other end of the ballast resistor
At this point I powered up the circuit for an hour and used a thermometer to measure the peak temperature on the back of the heat sink stars. It peaked at 48 degrees centigrade.
Step 6: Circuit Diagram and Ballast Calculation
Badly drawn diagram and calculations, there are many web sites that will help calculate the ballast resistor required
Step 7: Tap Lampshade and Attach Other Parts
You could glue the lampshade, but I designed the STL file with three M3 tap size holes.
Using a hand tap, tap the three holes with an M3x0.6
Then insert the triple cell base into the lampshade and use three M3 screws to attach it.
Insert the toggle switch and power socket into the lamp lower part (the holes are different sizes)
Apply a few drops of super glue to the underside of the cell triple base where it mates with the lower part.
Assemble the triple cell base and lamp lower parts. ensuring that the three holes on the base align with the three M3 screws so that the lampshade can be removed .
That's it
Step 8: Finished Lamp
This was designed using Autodesk Inventor, the complex organic finned design was easily achieved using the sweep function. The balloon shape was achieved using a cutting revolve shape once the sweeps had been completed.
Formlabs Contest
3D Printed Ornament Design Challenge
Make it Glow!
3 Comments
7 years ago on Step 8
Wow, that is beautiful. Excellent job.
7 years ago
awesome! !
7 years ago on Introduction
This is so cool!
