Introduction: Balloon Paint Dart Art
This project creates a giant, abstract drip-and-splat painting by attaching small paint-filled balloons to a large canvas and letting friends throw darts to burst them. It’s chaotic, joyful, and surprisingly beautiful.
Was this inspired by watching The Princess Diaries as a child? Yes. Yes it was.
For Balloon Prep
- Small party balloons. I recommend 5-7" size.
- A small funnel
- Acrylic or tempera paint (can be thinned slightly with water to improve flow)
- Bike pump with a narrow nozzle adapter
- Balloon tying tool (optional but very helpful)
- Paper towels / drop cloth for spills
For the Canvas Board
- One sheet 4' x 8' plywood
- A piece of canvas or heavy drop cloth large enough to wrap around the plywood
- Staple gun + staples
For Mounting Balloons
- Small nails or pins (e.g., ½" linoleum tacks)
- Hammer
- Plyers to hold the pins while you hammer
- Layout space on the ground to position balloons
For the Dart Station
- Darts that you don't mind getting splattered with paint
- Large tarp(s) or plastic sheets for the ground
- Outdoor space or garage with good airflow
- Optional step stool for kids
Step 1: Prepare Your Workspace
- Protect your workbench or garage floor with a tarp*. Paint-filled balloons drip a lot.
- Lay out:
- Balloons
- Funnel
- Paint colors
- Bike pump
You’re now ready to start creating your balloons.
*Note the lack of tarp in my photos. There's still a purple paint splat on my garage floor. Please learn from me and use a tarp.
Step 2: Fill Balloons With Paint
This step and the one following goes a lot smoother with two people working together - one to fill and one to inflate. Recruit a helper if you can!
- Stretch the balloon neck a few times so it’s easier to work with.
- Fit the balloon onto the funnel
- Pull the balloon’s opening up over the funnel stem so it seals.
- Hold firmly so paint doesn’t leak out.
- Add paint to the funnel
- Squeeze or pour ~1–2 tablespoons of paint into each balloon.
- Remove the funnel gently
💡 Tip: Don't overfill or adding air will be tricky and messy.
Step 3: Inflate Balloons With a Bike Pump
- Attach the narrow inflation nozzle to your bike pump.
- Insert the nozzle into the balloon’s neck while keeping a firm pinch to avoid spilling the paint.
- Pump in air until the balloon reaches a shape you like
- Remove nozzle and tie a tight knot.
Repeat for all your colors until you have a gorgeous box full of filled paint balloons.
Step 4: Prepare the Giant Canvas Board
- Lay the 4' x 8' plywood flat, either on the ground or a table/workbench.
- Center your canvas or drop cloth on top.
- Pull canvas tight around one long edge and staple every ~12 inches.
- Move to the opposite long edge, stretch tight, and staple.
- Repeat for both short edges.
- Check the front to ensure it’s smooth and tight.
This becomes the “target.”
Step 5: Attach Balloons to the Canvas
- Arrange balloons on the canvas surface to determine a pleasing random layout.
- Once satisfied, hammer a small pin or nail through the canvas just above each balloon knot:
- The nail acts as a miniature hook.
- This should puncture the balloon 'tail' and not touch the inflated part of the balloon.
- Space the balloons however you'd like.
Keep going until your board looks like a colorful constellation of paint bombs.
Step 6: Set Up the Outdoor Dart Station
- Prop the board upright against a hedge, fence, or easel.
- Lay down plastic tarps on the ground beneath it.
- Set out darts nearby.
Optional: Place a floodlight or string lights nearby if doing this at night — the splatter looks magical.
Step 7: Invite Friends & Throw Darts
This is where the art happens!
- Everyone takes turns throwing darts at the balloons.
- When a dart hits, the balloon bursts and paint splatters down the canvas, creating satisfying drips and arcs.
- The painting evolves unpredictably — you get splashes, waterfalls, spiderwebs, and drips.
- Keep going until all balloons are popped.
Step 8: Reveal & Clean Up
- Step back and admire the final artwork: a wild, expressive, multi-colored drip painting.
- Leave the canvas upright to allow the drips to finish falling.
- Remove popped balloon pieces once dry.
- Let canvas dry overnight.
Step 9: Enjoy or Repeat
Save it as a modern art masterpiece! You can reuse this canvas again and again to create layers or set up the canvas in different directions to have the drips going in various ways.
![Raised Bed Garden [for Those With Only Hand Tools!]](https://content.instructables.com/F2Q/UUXE/JUQSKGLC/F2QUUXEJUQSKGLC.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
