Introduction: Balloon Twisting
Hi, I am Tony. Your balloon twisting teacher. Today I am going to show you the simple way to tie a balloon.
Step 1: Preparation
Prepare a balloon pump and a balloon.
Step 2: Strech the Balloon.
Strech the balloon before you pump it.
Step 3: Pump the Balloon.
Place the balloon on the pump nozel, hold the balloon with your finger tip, and pump the balloon.
Step 4: Let's Tie the Balloon.
After pump the balloon with air and according to the size you want, release the air out a litle bit for you to tie the tip of the balloon, hold the tip of the well.
Step 5: Pull the Balloon Tip.
Pull the balloon tip upward.
Step 6: Pull the Balloon Tip and Place Above 2 Finger.
Pull the balloon tip place above 2 finger.
Step 7: Hold the Balloon Tip Well.
After this, hold the balloon tip and put it in between the forth finger.
Step 8: Turn Up Side Down.
Turn your balloon up side down, you will see the balloon nozel is undernerth in between the 3th and 4th finger.
Step 9: Pull the Balloon Tip Again.
Pull the balloon tip and cross over.
Step 10: Place the Balloon Tip in Between Your Finger.
After cross over, place the balloon tip in between your 2nd and 3rd finger.
Step 11: Then You Get Your Balloon Tip Like This.
This is what it looks when you get it right. =)
Step 12: Pull Down and Tie Over the Balloon Tip.
Gently pull the tie over the balloon tip and out from your 2nd and 3rd finger.
Step 13: This Is the Perfect Way to Tie a Balloon.
Tada~! This is it. The perfect way to tie the balloon and here you got on your balloon.
