Introduction: Banksy Box Ver.1
A lit-up box picture frame. Simple but awesome. I'm choosing to use it for stencil based artwork(Graffiti Mostly). The simple shapes and lack of color suit the project very well. This is V.1 because I'm already working on versions 2 and 3. Having given this one away as a gift, I need some more for my house and I am currently underway making more. If you like this idea and thinks its the coolest thing ever done with 12 LEDs and a printer, please vote for me in the Holiday Gifts contest. TOP RIGHT CORNER Or follow this link.
Step 1: Parts & Tools
Parts:
Sheets of Vellum paper
Box or Shadow picture frame
12 LEDs( or more)
Wire
Power supply(regulated 5volts or Old Cell Phone Charger)
220-500ohm resistors(You do the math)
6 sticks hot glue
Tools:
Printer
Solder Iron
Ruler
Drill
Glue Gun
Step 2: Print Your Design
Print your chosen design and trim it to fit your box frame. My box is 8x10. A convenient size for printing. I ripped the designs of the internet, changed the size and centered the images in MSWord. Printed a rough draft on regular paper. Checked it out. Then load the Vellum paper, Press Print.
Using a straight edge, cut the paper down to size so that it fits nicely into your picture frame.
Step 3: LED Layout
Layout a grid of 12 LED's equally spaced apart. This is where that ruler and basic math comes in handy.
The drill holes in for the LEDs to fit through.
Place LEDs through holes.
Secure with Hot Glue
Use more hot glue on top of the LEDs to diffuse the light.
Step 4: Circuit Making
The basics here are taking a 5volt power supply re-used from an old cell phone charger and wiring up a dozen LEDs. I used another 5volt regulator, LM805 just to be sure that 5 volts is coming through. That part is probably totally unnecessary but allows a battery to be used if I so chose.. All the lights are wired in parallel. I used 500ohm resistors and superbright 5mm LED.
Step 5: Putting It All Together
Try out revisions and multiple designs. I decided to give this as a gift to a friend who loves Fight Club. Not wanting to force him to be committed to buying 9volt batteries the rest of his life, I jacked the power from an old cell phone charger. Had I originally intended to do this, I wouldn't have built the 5volt circuit regulator as it's kinda unnecessary now. I printed off a new image and colored it in with Sharpie. Cut it down to size and viola, a personalized awesome wall light thingy. Added are some other image ideas. Any image will work. I prefer black and white graffiti stencil. But feel free to try out whatever art you are into. For a total cost of under $20 US dollars, you can get crazy printing different skins and changing your awesome wall light to whatever suits your daily mood.
Second Prize in the
Holiday Gifts Challenge
ShopBot Challenge
Make It Glow Challenge
14 Comments
10 years ago on Introduction
Updates...... I'm made one that I can keep now with upgrades. This one uses a LiPo battery, AdaFruit's charging breakout board and a switch to turn it on and off. The wiring is cleaner and the picture frame is thicker. I also added 6 more LEDs to this one.
This is great! I love Banksy, I know there are artist that don't but there is something so deep and peaceful about what he does, I just love it. Well that and sometimes even tho I know he's made a stencil and he's using spray paint, it's awesome some of the size and detail in his work! Anyway, I love this, nice job!
Inspired by this, I decided to make a basic light box, merely because I have all the materials and very little electronics experience. Pics when finished!
I look forward to seeing it.
How much current does your circuit consume ? You might save some power and battery life using a constant current LED driver and removing the resistors.
300mA, give or take. I've never used a constant current driver. But I'll be sure to look it up and let ya know. My first guess and inclination is that it'll have thick caps that'll make my circuitry thicker than it can be. But I'll definitely check it. Thanks.
The thing is that you waste some power inside the resistors. On the other hand, you might waste some inside the LED driver as well.
One candidate would be the TPS61042. It's something I want to try for a similar project as well but did not have the time to look into yet.
Thanks for the part number. TI gives these away as samples. I just order 3 along with a bunch of other FREE stuff. If you're not registered with Texas Instruments to get free samples, you should.
http://www.ti.com/product/tps61042
Now we'll see if I can figure out how to use these.
Yep, I ordered some of them too :-). Ordered some TLC5940 as well which look easier to use (DIP package + parallel circuit instead of serial)
I will do this.
It's real easy to make. Super cool and I'd love to see what image(s) you use as your wall art lamp. The possibilities are really endless. I half finished with my El Panel Portal version. It's coming out real nice.
The one I am making is much simpler, mainly just for temporary display of stencil art, not permanent. I think I will probably just cut up a lamp and use that. It will probably end up more like a light box than a display peice.
When I have time to do it, I will for sure include pictures though.
Wow, this looks amazing! I'd love to have a frame-light like this where I could but my own images!
That's the beauty and ease of this design. With a regular printer and cheap Vellum available at Micheal's, Jo-Ann Fabric, and paper stores; You can print any image you want. And when It's battery powered, you can place it anywhere. I've got one in mind for my bathroom, Closet lights using photocell triggers, and large array of these for an art piece.
