Introduction: Baofeng UV-5R Data Cable
Easy DIY data cable for the popular Baofeng UV-5R Radio and many brands (See supported hardware at CHIRP Software web site)
Step 1: Material You Need
1.- USB CH340G very low cost adapter from any vendor
http://www.dx.com/es/p/usb-to-ttl-ch340g-converter...
2.- 3.5mm Plug
3.- 2.5mm Plug
4.- Chirp Sotware from
https://baofengtech.com/download
Step 2: Solder Cables to Plugs
You can use the provided cables of the USB CH340G (it come with 6) only 3 is necessary, please use follow image to make correct connections
help with stand in order to solder carefully the wires, be carefull as the connectos become very hot when you use the solder station
Step 3: Test It
Its done!, only 3 wires are needed,
Noe you can download now the Chirp software and got all data settings from the radio.
