Introduction: Barrel (Drum) Lamp Shade
Make your own barrel lamp shade using some simple materials picked up at craft and hardware stores.
Step 1: Getting Started
I was looking for a way to cover an ugly light fixture instead of changing the it since I didn't want to spend that kind of money or deal with the electrical work. Because I couldn't find one I liked, I created my own. Please note that I'm just using this as a cover. If you would like to actually integrate a light and hang it as a fixture I'm sure it's possible, but you'll have to figure out the additional steps.
The items I used are:
Shade
2 23'" quilting hoops
12"x18" heavy duty template plastic (also found in the quilting section of the craft store)
Ribbon
scotch tape
Mounting
3 1-1/4" mug hooks
3 picture hangers
6 1-1/2" S-hooks
Tips: The plastic can get static and pick up a lot of dust. I wiped mine down with a dryer sheet in the beginning and at the end to cut back on it.
You will need to calculate how many plastic sheets you need by figuring out the circumference of your shade. The formula for this is circumference = pi x diameter. In my case C = 3.1415 X 23". My circumference is about 72.25". I used 18" sheets so 72.25"/18" = 4.01. I needed at least 5 sheets to have enough to go all the way around.
You could pretty much use any kind of material for the sides of the shade, but I think something with some rigidity will hold up better.
No matter what material you use, be sure not to place it to close to the bulb for safety purposes.
Shade
Ribbon
scotch tape
Mounting
3 1-1/4" mug hooks
3 picture hangers
6 1-1/2" S-hooks
Step 2: Hoop 1
Note: Quilting hoops consist of two rings - inner and outer. by loosening the outer ring you can slide material between the two rings.
Begin by loosening the wing nut on one hoop. Do not completely remove the wing nut, but loosen it enough that the plastic will slide easily between the inner and outer rings.
Lay the hoop on a flat surface and begin placing the plastic between the inner and outer rings. I overlapped the sheets quite a bit, but you can do it however you like.
Once the sheets are completed tighten the Wing nut without lifting. If you lift before the hoop is tightened all your sheets will slide through.
Once tightened you can flip the loop over and check the edge. You may need to wiggle the hoop and sheets to make sure the edges of the sheets are completely hidden
Step 3: Hoop 2
Loosen the second hoop and completely remove the inner circle.
I added some ribbon to this hoop. You don't have to. You can just skip this ribbon crap if you don't want it.
Tape the ribbon onto the outer edge of the inner circle. (This tape won't be seen as it will be hidden by the outer ring when finished.) Run the ribbon back and forth across the circle in whatever manner you like. I found that I needed to use tape every time the ribbon wrapped around the circle to keep it from sliding. When you're done, put this circle off to the side for a second.
Now take the outer circle from the second hoop and lay it on a flat surface. Take the previously assembled hoop with plastic pieces and sit the raw plastic edges inside the second hoop. It may take some work, but make sure all the edges are inside the second hoop.
Take the circle with the ribbon and carefully slide it into the structure through the top. Push it all the way to the bottom until the second hoop is back into it's original state.
Tighten the wing nut on the second hoop without lifting as with the first hoop. Once tightened, flip the structure and check for exposed plastic edges again. Make any adjustments as needed.
Step 4: Mounting
Using hot glue attach the picture hangers inside the Hoop 1 (without the ribbon). I used 3 in a triangle pattern.
Measure the distance between each hook and use it to plot the holes for the ceiling.
Screw your mug hooks into the ceiling. I had to make pilot holes with a small drill bit. Just depends on the ceiling.
I used two S-hooks from each mug hook. Add more to hang lower or remove some to hang higher.
Connect the S-hook to the picture hangers.
You're done.
You're done.
Step 5: Update 03/30/09
I wasn't feeling the ribbon. It was too fussy for the rest of the design, and I didn't want the exposed bulbs to be visible from below so I changed it. See below:
Take down the shade.
Remove the bottom ring and take off the ribbon and tape.
Use the ring to trace a circle onto a piece of styrene. (Styrene is the plastic that you'll usually see covering fluorescent lights in offices or sometimes in kitchens. I picked it up at the hardware store.
2 'x 4' for $6)
I cut the Styrene using scissors. Go slowly and be careful because the styrene likes to crack. The guy at the store suggested using a table saw with a very fine blade. That would probably be faster and give a cleaner edge, but I don't have a table saw.
Replace the bottom hoop as done previously in step 3.
Once complete, I placed the circular piece into the shade through the top while being sure that it sat completely on the small edge created by the inner ring of the bottom hoop. If you're feeling daring you could glue it into place, but I like that everything is loose so I can change things up.
Rehang and you're done.
2 'x 4' for $6)
Step 6: Other Tips
Instead of ribbon you could also put more plastic to block the view of the old fixture completely.
Try other papers with different patterns or colors to go with your room.
I lined up the wing nuts on both hoops to keep things uniform. If you don't like them you could hang the shade so the wing nuts are in the least visible space.
Compact fluorescent bulbs give off less heat than traditional bulbs so you may want to consider using them for safety. If not you can use a lower watt traditional bulb.
Quilt hoops come in lots of sizes and colors (plastic). you could make a longer version by just adding another row of plastic and another hoop.
