Introduction: Basic Portrait Enhancing and Retouching Photoshop CC and Camera Raw Tutorial
Step 1: Open Your Image in Camera Raw Using Adobe Bridge.
1. *If you are editing a JPEG, duplicate the background, go to Filter, Camera Raw Filter and continue from there.
2. Using the White Balance tool, look for a grey area in the photo (read tip) and click.
Tip: Look at the RGB values beneath your histogram, ensure that they are all within 10 digits of each other.
This automatically corrects the overall tone of the photo.
3. Open the Tone Curve bar and select the Point tab, slightly drag the curve in desired directions (be very light
handed with this step, a little goes a long way).
For this image: Input = 192 and my Output = 207.
4. Open the Detail bar and add Luminance, valued 8-15, depending on the amount of noise in your photo. This also
softens the portrait.
5. Next, open the Lens Correction bar and navigate to the Profile tab. Enable lens profile correction. Open the
Color tab and click Remove Chromatic Aberration.
6. Now, open the Effects tab and Dehaze the image if the overall brightness and/or haziness is too much. (If you
have not upgraded to CamRaw 9 you can skip this step).
Step 2: Straighten
7. Now find the Straighten tool in your main toolbox. Double click it and click on any other tool to apply effect.
Step 3: Spot Removal
8. Navigate to the Spot Removal tool, zoom in on your image and start clearing up any spots, marks, etc. (If the
marching-ant circles distracts you, simply click the “show overlay” block.
Step 4: Graduated Filter
9. Open the Graduated Filter tab. Ensure that at least one slider (I use exposure ‘-‘ ) is set to less than, or more
than, 0. Now you can drag the filters from the outsides of the photo, into the subject (hold shift for easy control).
Once you have done this you can adjust each slider separately to reach the desired effect. (Do not worry if this
also effects the subject, we’ll clean that up soon.)
10. Select the filter you want to adjust (clean up subject), and select “Brush”. Now adjust size as needed and clean
up your subject, be careful not to go out of boundaries as it can create a halo-effect on your subject (if you do,
just paint it back again).
Step 5: Acknowledgements
Now, simply open the image and keep an eye out for Part 2: Basic Retouching and Enhancing.
TRIED THIS TUTORIAL? Please share it with us via e-mail!
Make sure to visit our website for more wonderful content.
http://www.bluebloodphotography.co.za
Copyrighted to Blue Blood Photography. You may not distribute this tutorial for personal gain, or accept any payment for the use of it.
