Introduction: Basic Survival House
This house uses some techniques from the cottage so if I was you I would check it out
Step 1: Frame
Copy the layout from the image with oak or spruce wood depending on which wood you've got most of.
Step 2: Build It Up, Build It Up
Build up the wood two more high which gives a total of three high.(the cobble and glass rant needed).
Step 3: Joining the Dots
Like we did in the cottage join the wood beams with more wood.
Step 4: Flooring
Using planks, fill in the ground
Step 5: Double Layer Baby
With, guess what, more wood build up on the corner of the house
Step 6: Roofy Roof
Pictures will explain this one
Step 7: The Walls
Using oak and cobblestone make the using this pattern
Step 8: Top Floor
Like we did with the floor fill in the top layer
Step 9: Stairs
Stairs are simple I don't need to explain that do I?
Step 10: Top Layer Walls
Like we did with the bottom, do the walls with wood planks
Step 11: Roof
Using stairs, fill in the roof
Step 12: Windows, Doors and Fences and Farm
Fill in the holes with glass and doors, join up the top with fences and finally in the corner you are done
Step 13: Finished
I hope you like it and tell me what you think
