Introduction: Basketball Basics
I've always played basketball when I was younger. It has always been a part of me and getting to share that with others would be a blessig.bas
to get started it does not take much. You will need a basketball and a goal
Step 1:
you might begin by learning how to dribble. In order to do so all you have to do is basically with one hand throw the ball straight down from you arm and it should come back up to your hand
Step 2:
Once you get dribbling down you can begin learning how to shoot. You get the ball in your dominant hand and make your arm create an L and as you extend aim your hand towards the goal and allow the ball to roll off your fingers. Once the ball is released your arm should look like your reaching in a cookie jar on the top shelf
Step 3:
After you get that down you then put dribbling and shooting together. You run towards the goal and judge your distance. Once you get close enough to the goal on one side that you can clearly see the square on the goal allow the ball again to roll off your fingers after your arm is extended this is called a layup
