Basketball Leather / Walnut Sculpture for the Golden State Warriors
1,676
15
12
Introduction: Basketball Leather / Walnut Sculpture for the Golden State Warriors
About: My name is Blake, I make things for a living. I love experimenting with new materials to create sculptures, furniture and everything in between.
In collaboration with Sports and the Arts, and the Golden State Warriors, I created a one of a kind wall relief sculpture for the players and coaching staff. This sculpture is permanently displayed in the Chase Center, just outside the team's locker room. The Warriors wanted a sculpture that payed homage to their roots in Oakland while incorporating phrases, words and accomplishments meaningful to the team.
This Warriors sculpture spans over 8 feet long and 5 ft tall. It uses premium basketball leather and English Walnut. The lettering was CNC'ed, then using the smallest cobblers nails secured into the sculpture. This sculpture was over a year in the making. I ended up making 3 sculptures for this because I was dissatisfied with the first two ( I only showed the first one in this video). There were lots of ups, downs and learning along the way but it is these challenges that make it more rewarding in the end. I I am extremely happy with how this sculpture turned out and cannot thank everybody that helped me along the way.
Step 1: Make Design and Enlarge to Full Scale
The first step for any large project like this is to sketch out the design and then enlarge it full scale. This piece will be 8ft long by 5ft tall.
Step 2: Cut Out Design and Glue Up Pieces
The next step is to cut out the design. For this sculpture, I created a 3-D look by making 4 different layers of the tree. Each layer would have different branches cut out, creating height differences between each layer. I used a jig saw and flush trim bit in order to accomplish this. Once all 4 layers were perfectly matching, I glued and used 18 gauge brad nails to fasten them together.
Step 3: Cut Leather and Apply.
I got my basketball leather from Spalding, the official basketball of the NBA. It came to me in huge sheets of leather. I cut everything down to size and then used painters tape to trace each branches design. I then used construction adhesive along with hot glue to attach the leather to the wood. I trimmed off the access with a razor blade.
Step 4: Mill Up Walnut Veneer.
I then took my work over to my friends shop to mill up some English Walnut. We jointed each board, planed, cut to thickness on the bandsaw and then ran everything to the drum sander in order to get 1/32" thickness walnut veneer. I then meticulously cut each veneer to boarder every single side of the exposed plywood.
Step 5: Finishing Work.
I spent around 2 months to do the fine details of the walnut veneer. Each piece had to be perfectly cut to fit each unique branch. I used a hand plane and chisel to cut down the borders. I then did weeks upon weeks of sanding everything down to 220 grit.
Step 6: Walnut Finish.
I used Festool's heavy duty finish to finish all the walnut. I had to tape of every square inch of leather in order to not get any finish on the leather.
Step 7: Lettering
The client wanted hundreds of meaningful words spread throughout every branch of the tree. I CNC'ed every letter to 3/4" tall. I then drilled each letter multiple times in order to secure them to the tree using the tiniest of cobblers nails. This process took a VERY long time!
Step 8: Mock Install and Final Install
A custom mounting bracket was made and we did a mock install in the workshop. Once that was secured we took it down, shipped it to Chase Center and did the final install.
Step 9: Check Out the Build in It's Entirety!
Be the First to Share
    • Pi Day Speed Challenge
    • Trash to Treasure Contest
    • Sculpt & Carve Challenge
    12 Comments
    Cherpur
    Cherpur
    10 days ago on Step 1
    What an amazing piece of art work, fabulous work!!
    oceanprimed
    oceanprimed
    Reply 10 days ago
    Thank you so much!
    DawnN2
    DawnN2
    11 days ago
    A truly incredible work of art. Thank you for showing the first "failed" attempt. Your hard work and diligence totally paid of. My fear would have been spelling something wrong!! Great job!!
    oceanprimed
    oceanprimed
    Reply 11 days ago
    Thank you. I was debating leaving it out, but decided I had to show the first failed attempt. You have no idea how many times I ran spell check on each of these words lol. Thanks for watching!
    muadibe
    muadibe
    12 days ago
    Wow, that is brilliant. A true labour of Love, very impressive piece of work.
    oceanprimed
    oceanprimed
    Reply 12 days ago
    Thank you so much!
    thegamepuppies
    thegamepuppies
    14 days ago
    I'm a huge fan of the Golden State Warriors and some day, the players will see this.
    oceanprimed
    oceanprimed
    Reply 14 days ago
    Awesome. This was actually made for the players. They had input on all the wording on the tree. It is located just outside their locker room
    thegamepuppies
    thegamepuppies
    Reply 14 days ago
    oh that's cool. Did you see the players? Steph Curry, Draymond Green? I always want to meet Stephen Curry
    oceanprimed
    oceanprimed
    Reply 12 days ago
    They walked through as we were installing, but did not talk to them unfortunately!
    oceanprimed
    oceanprimed
    14 days ago
    Thank you so much! Glad you enjoyed it
    seamster
    seamster
    14 days ago
    This is intense. I love the results, and it's great to see the process. Very well done!
