Introduction: Batarang From "Arkham Asylum" Game
This is an instructable for making a replica of the batarang seen in the game “Batman: Arkham Asylum.” I wanted a batarang that unfolded with an action similar that that in the game. Not counting the cost of the tools, which I had already, and the paint (ditto), the entire project cost me about $17 and took perhaps 10 hours.
Step 1: Tools and Shopping List
I decided to make this prototype batarang out of Plexiglass, because a) it is easy to work b) it has no grain and doesn’t splinter or chip c) it is transparent, which helps with aligning the pieces d) it takes a metallic paint better than wood, and, finally, e) I didn’t have access to a metal-cutting bandsaw. Needless to say, you won’t be knocking any thugs unconscious with this one. You probably won’t be throwing it anywhere, either, unless you want to see your hard work shatter into bits.
Shopping list:
.093”x11”x14” Lexan (or Plexiglass) sheet
Furniture joint connector nut, ¼”-20 thread
¼” x 3/8 flathead machine screw
four neodymium disc magnets .47” x .11” (12mm x 3mm)
Tools required:
Coping saw
Straight and curved files
Power drill
Various drill bits, including a ½” spade woodborer
“Liquid Nails” clear silicone adhesive
Cyanoacrylate superglue
Two part epoxy resin
Sandpaper
Shopping list:
Tools required:
Coping saw
Power drill
Sandpaper
Step 2: Cutting the Plexiglass to Shape
The Lexan sheet was too thin, so the first thing I did was cut it in half across the long axis and glue both pieces together, resulting in a sheet 11” x 7” x 0.186” thick. A word on the glue: I used three types of glue in the project, Liquid Nails silicone adhesive, two part epoxy resin, and cyanoacrylate superglue. There’s a lot of prying stress put on the various pieces of the batarang while it is being filed into shape, and the Liquid Nails quits after a while. This doesn’t matter, as I had to pull it apart several times to correct mistakes. When everything was ready to be finally glued, I used cyanoacrylate which is notoriously unforgiving of mistakes. For gluing these two sheets together, the superglue is preferable.
I found an image of the batarang on the internet, and printed it out as a template at the size I wanted. Because I was going to have a hinged batarang, I only used one wing as the template for both halves, which helps with symmetry. It also helps that friendly Instructables user, InfiniTTTy, then drew up my template as a nifty .png file, which you can find at the bottom of this page. I then cut out the three pieces of the ‘rang with a coping saw. If you are going to do the cutting with a bandsaw, make sure you have good dust extraction – unlike sawdust, plexiglass dust can get hot enough to catch fire.
I call the three pieces ‘the fixed wing,’ the ‘pivoting wing,’ and ‘the back piece.’ The fixed wing and the back piece will join together to make the 'back assembly,' the half of the batarang you hold in your hand. This is a right-handed batarang, but you can easily reverse the pieces for a left-handed one. The fixed wing is just the pivoting wing with the circular axis removed, and the back piece is just the center of the batarang with a bit of overlap where the magnets will be placed.
Step 3: Shaping the Wings
The next step, after smoothing off the rough edges with a file to make them prettier and easier to handle, is to make the three pieces true to each other. The easiest way to do this is to make the backing piece as perfect and symmetrical as possible, decide which way up it will face, and base the other two wings off that. Mark the center of the back piece with a dot.
First off, try and align the pivoting wing with the backpiece, and correct the pivoting wing where it needs it, using a file. Once the places where they overlap matched up, mark the pivoting wing with a dot that overlaps the back piece dot. Hold the pivoting wing in place with a small clamp or clothespin and shape the fixed wing until all three pieces fit together neatly.
Step 4: Beveling the Wing Edges
Now it is time to bevel the chisel edge of the wing blades. Mark a line that runs parallel to the edge of the wing, then, using a flat file, form the blade. Because you are using two sheets of plexiglass glued together, it’s easy to mark your progress by the center join (but because you are not making an actual working blade, you don’t need to file all the way down to the center of the wing thickness). Spend some time on this: a good consistent bevel is important to the final look of the batarang, although paint will help if you can’t manage it.
When this is done you can glue the back piece to the fixed wing to form the back assembly, the half of the batarang you hold in your hand (assuming you are right handed). When the glue dries, do a final filing and sanding of the places they overlap to make them completely true.
Step 5: Making the Axle
Now make the axle of the batarang. Tape the two wings together in the final position, and drill a pilot hole though the center. Separate the wings again, and drill a hole in the pivoting wing just large enough to accept the machine screw fairly tightly (15/64” was right for me). Then through the fixed wing assembly drill a hole large enough to accept the furniture joint connector (3/8” was perfect). The connector needs to pivot smoothly but not be loose.
I then countersunk the machine screw hole in the pivoting wing, and, using the large 3/8” bit, recessed the other side of the hole to accept a small portion of the furniture connector. This was because the furniture connector was a little too long and I didn’t want the wing to be loose when folded up. I could also have ground down the connector a bit but this seemed easier, and it worked fine.
Step 6: Placing the Magnets
Now to place the magnets that will hold the batarang in place when it is opened. Tape the batarang together in its final position, and drill a pilot hold through the part where the backing piece and the pivoting wing overlap. Exact placement of this hole is not critical, just make sure it's not too close to any of the edges. Then widen this hole with the ½” woodborer bit. I used a ½” because my magnets were just a tiny bit smaller than that, but if you use different magnets from me, adapt the hole to fit. Using tape to separate the holes in the wings (so you don’t glue the wings together), glue the magnets in place. I used two per wing. Make sure you align the North/South correctly so that the wing will not repel itself! The magnets won’t take a lot of stress, so I used two part epoxy resin for this job, which also filled the gap around the magnets.
Step 7: Finishing Up
You can now assemble the batarang. I glued a little plastic widget over the machine screw head to cover it. You can still take the batarang apart by unscrewing the furniture connector from the rear. This is why you want to machine screw to be fairly tightly in place.
When this is done, you are almost finished! All it needs is any final shaping and filing, a bit of sanding of the edges, and you are ready to paint. I used a satin black spray paint specifically for plastic, and bronze model paint for the wing bevels.
