Introduction: Batch Colours, Using Batch
First Off I Must Say That Prof. Pickle Helped Me Fix This Batch File And for That I Must Credit His Work
His Profile Is: www.instructables.com/member/Prof.+Pickle/
He Has Helped Me With The Large Problem I Was Having And I hank him Very Much
If You Have Always Wanted To Know The Codes For the Colours In Batch Files This Batch File Will Help You Greatly, My friend And I Made A Batch File To Help People Get The Codes For Their Batch File Projects, This Is All My Coding so If You Wish To use It For Something Please Ask Me before You Do, I Will Almost definitely Say Yes But I Wish To Know What It Is Being Used For And Who Is Using It.
If There is Anything Wrong With It Or You want Me To Add Something To It Simply Tell Me in The Comments And I Probably Will
I Have Added All Of The Colours That I Know Of, I do Not Believe That there Are Any Other Colours But AS I Previously Stated If There Is Something to Add Simply Write It In The Comments And I will More Than Likely Add It.
First Things First You will Need To Open Up A New text Document (.txt) And copy And paste The Following Into It:
@echo off
color 0a
title Batch Colour Help, Using Batch
echo This Batch file Will Tell You What Letter Or Number Is the Code For The Colour You Would Like
echo Obviously You Have To write color As The Batch file Code Before You can Type The Corresponding Letters And Numbers For The Colours
pause
cls
:start
cls
color 1a
echo Choose The respective Number For The Colour You Would Like
echo.
echo.
echo.
echo (1).............Black
echo.
echo (2).............Dark Blue
echo.
echo (3).............Dark Green
echo.
echo (4).............Dark Aqua
echo.
echo (5).............Dark Red
echo.
echo (6).............Dark Purple
echo.
echo (7).............Dark Yellow
echo.
echo (8).............Dark White
echo.
echo (9).............Grey
echo.
echo (10)............Bright Blue
echo.
echo (11)............Bright Green
echo.
echo (12)............Bright Aqua
echo.
echo (13)............Bright Red
echo.
echo (14)............Pink
echo.
echo (15)............Bright Yellow
echo.
echo (16)............Bright White
echo.
echo.
echo !!Remember The First Number Or Letter (That Is The Code For A Colour)Is The Background Colour!!
echo !!And The Second Number Or Letter Will Be The Text Colour!!
set input=
set /p input= Corresponding Number:
if %input%==1 goto black if NOT goto start
if %input%==2 goto db if NOT goto start
if %input%==3 goto dg if NOT goto start
if %input%==4 goto a if NOT goto start
if %input%==5 goto dr if NOT goto start
if %input%==6 goto dp if NOT goto start
if %input%==7 goto dy if NOT goto start
if %input%==8 goto dw if NOT goto start
if %input%==9 goto g if NOT goto start
if %input%==10 goto bb if NOT goto start
if %input%==11 goto bg if NOT goto start
if %input%==12 goto ba if NOT goto start
if %input%==13 goto br if NOT goto start
if %input%==14 goto p if NOT goto start
if %input%==15 goto by if NOT goto start
if %input%==16 goto bw if NOT goto start
exit
:black
cls
color f0
echo BLACK
echo.
echo The Code For Black is:
echo.
echo color 0
echo.
echo What Would You like To Do Now?
echo (1)...Go to Start
echo (enter)...Exit
set input=
set /p input= Choice:
if %input%==1 goto start
exit
:a
cls
color 03
echo DARK AQUA
echo.
echo The Code For Aqua is:
echo.
echo color 3
echo.
echo (enter)...Exit
set input=
exit
:db
cls
color 01
echo DARK BLUE
echo.
echo The Code For Dark Blue is:
echo.
echo color 1
echo.
echo (enter)...Exit
set input=
exit
:dg
cls
color 02
echo DARK GREEN
echo.
echo The Code For Dark Green is:
echo.
echo color 2
echo.
echo (enter)...Exitt
set input=
exit
:dp
cls
color 05
echo DARK PURPLE
echo.
echo The Code For Dark purple is:
echo.
echo color 5
echo (enter)...Exit
set input=
exit
:dr
cls
color 04
echo DARK RED
echo.
echo The Code For Dark Red is:
echo.
echo color 4
echo.
echo (enter)...Exit
set input=
exit
:dw
cls
color 07
echo DARK WHITE
echo.
echo The Code For Dark White is:
echo.
echo color 7
echo.
echo (enter)...Exit
set input=
exit
:dy
cls
color 06
echo DARK YELLOW
echo.
echo The Code For Dark Yellow is:
echo.
echo color 6
echo.
echo (enter)...Exit
set input=
exit
:g
cls
color 08
echo GREY
echo.
echo The Code For grey is:
echo.
echo color 8
echo.
echo (enter)...Exit
set input=
exit
:ba
cls
color 0b
echo BRIGHT AQUA
echo The Code For Bright Aqua is:
echo color b
echo.
echo (enter)...Exit
set input=
exit
:bb
cls
color 09
echo BRIGHT BLUE
echo.
echo The Code For Bright Blue is:
echo.
echo color 9
echo.
echo (enter)...Exit
set input=
exit
:bg
cls
color 0a
echo BRIGHT GREEN
echo.
echo The Code For Bright Green is:
echo.
echo color a
echo.
echo (enter)...Exit
set input=
exit
:br
cls
color 0c
echo BRIGHT RED
echo.
echo The Code For Bright Red is:
echo.
echo color c
echo.
echo (enter)...Exit
set input=
exit
:bw
cls
color 0f
echo BRIGHT WHITE
echo.
echo The Code For Bright White is:
echo.
echo color f
echo.
echo (enter)...Exit
set input=
exit
:by
cls
color 0e
echo BRIGHT YELLOW
echo.
echo The Code For Bright Yellow is:
echo.
echo color e
echo.
echo (enter)...Exit
set input=
exit
:p
cls
color 0d
echo PINK
echo.
echo The Code For Pink is:
echo.
echo color d
echo.
echo (enter)...Exit
set input=
exit
If You Guys Have Any Problems/Bugs That You Find With My Batch File Or You Want Me To Make A Different Batch File Please Let Me Know In the Comments Or By Emailing Me At MidgetCoder@gmail.com
Thanks Guys Have A Good Day.
@echo off
color 0a
pause
cls
:start
cls
color 1a
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
set input=
exit
:black
cls
color f0
echo BLACK
echo.
echo.
echo color 0
echo.
echo (enter)...Exit
set input=
exit
:a
cls
color 03
echo DARK AQUA
echo.
echo.
echo color 3
echo.
echo (enter)...Exit
set input=
exit
:db
cls
color 01
echo DARK BLUE
echo.
echo.
echo color 1
echo.
echo (enter)...Exit
set input=
exit
:dg
cls
color 02
echo DARK GREEN
echo.
echo.
echo color 2
echo.
set input=
exit
:dp
cls
color 05
echo DARK PURPLE
echo.
echo.
echo color 5
echo (enter)...Exit
set input=
exit
:dr
cls
color 04
echo DARK RED
echo.
echo.
echo color 4
echo.
echo (enter)...Exit
set input=
exit
:dw
cls
color 07
echo DARK WHITE
echo.
echo.
echo color 7
echo.
echo (enter)...Exit
set input=
exit
:dy
cls
color 06
echo DARK YELLOW
echo.
echo.
echo color 6
echo.
echo (enter)...Exit
set input=
exit
:g
cls
color 08
echo GREY
echo.
echo.
echo color 8
echo.
echo (enter)...Exit
set input=
exit
:ba
cls
color 0b
echo BRIGHT AQUA
echo color b
echo.
echo (enter)...Exit
set input=
exit
:bb
cls
color 09
echo BRIGHT BLUE
echo.
echo.
echo color 9
echo.
echo (enter)...Exit
set input=
exit
:bg
cls
color 0a
echo BRIGHT GREEN
echo.
echo.
echo color a
echo.
echo (enter)...Exit
set input=
exit
:br
cls
color 0c
echo BRIGHT RED
echo.
echo.
echo color c
echo.
echo (enter)...Exit
set input=
exit
:bw
cls
color 0f
echo BRIGHT WHITE
echo.
echo.
echo color f
echo.
echo (enter)...Exit
set input=
exit
:by
cls
color 0e
echo BRIGHT YELLOW
echo.
echo.
echo color e
echo.
echo (enter)...Exit
set input=
exit
:p
cls
color 0d
echo PINK
echo.
echo.
echo color d
echo.
echo (enter)...Exit
set input=
exit
