Introduction: Batch Copy
I thought i would make a simple tutorial on how to make a batch file copy a directory into a file called data. Although you cannot copy a directory that has the batch files eomwhee in it even if its in a sub-direcotry.
Ok Lets being.
Steps:
First: Right Click,Select New, Select Notepad/Text Document.
Now select File, Save as, change file type to All files, Call it COPY.bat
Step 1: Color/Title
right click COPY.bat and select edit
type in the following code to set the colors and title
@echo off
color 0c
(This color code "0c" will set the color of the backgound and the text)
the 0 is for the black background and the c is for red text.
-feel free to play around with these colors.
title Alex's Copying Program
if not exist data MD data
(this will set the title to Alex's Copying program)
and the code *if not exist data MD data* sets it to make a file called data if it already does not exist-this will be the folder that files copy to-
@echo off make you not able to see the code when running the program
Step 2: Password
(this is optional)
:start
cls
echo enter password to continue
set/p pwd="Password: "
if %pwd%==alex goto correct
if not %pwd%==alex exit
cls
the codes:
:start - a new section thing
cls - stands for *clear last script* which just make a all the previous code invisible
echo enter password to continue- makes the words *enter password to continue* appear when running the program
set /p pwd="Password:" - makes the password possible
if %pwd%==alex goto correct - makes the password set to alex and go to next secion if correct
if not %pwd%==alex exit - makes the application exit if the entered password is not alex
cls - clears the last set of writing in program so its more tidy
Your code so far:
@echo off
color 0c
:start
cls
cls
Step 3: Correct Password
:correct
echo Correct Password!
ping localhost -n 2 >nul
cls
goto command
Code Meanings:
:corect - another section thing.
echo Correct Password! - lls you that you got the password corect
ping localhost -n 2 >nul - makes it wait 2 seconds to continue
cls- makes last script invisible again
goto command - directs it to the section :command
Code so far:
@echo off
color 0c
:start
cls
cls
:correct
cls
goto command
Step 4: Continue or Quit?
enter the flowing code to make it either quit the program or continue on
:command
echo type start to begin!
echo or Q to quit application
goto next
:next
set/p pwd=""
if %pwd%==start goto start2
if %pwd%==q exit
if %pwd%==Q exit
if not %pwd%==start goto unknown
Code Description:
:command - another section thing
echo type start to begin! }
echo or Q to quit application}states what the program will say at this point in time
goto next - will goto the section *:next*
:next - a section thing
set /p pwd="" - sets a password with no description
if %pwd%==start goto start2 - sets it to go to *:start2* section is you tupe start
if %pwd%==q exit }
if %pwd%==Q exit }makes the letter q exit without being case sensitive
if not %pwd%==start goto unknown - *should send to section unknown if not start/q/Q*
Cuent Code:
@echo off
color 0c
:start
cls
cls
:correct
cls
goto command
:command
goto next
:next
set/p pwd=""
if %pwd%==q exit
if %pwd%==Q exit
Step 5: The Copy Command
Now enter this in:
:start2
cls
echo Enter the File path
set/p pth="Path: "
if not exist %pth% goto ac
cls
echo Copying...
xcopy /e /c /q /h "%pth%" "data" || goto error
echo.
echo Copy Complete!
echo.
Code Description:
Start2 - should know this by now
cls - should remember
echo Enter the File path - The text displayed
set/p pth="Path: " - Sets it to recognize a path file
cls- should knoe
echo Copying... - what it displays
xcopy /e /c /q /h "%pth%" "data" || goto error - tries to copy the path file or exits program
echo. - makes a space
echo Copy Complete! - displays text
ping localhost -n 2 >nul - gives 2 seconds to read text
exit - closes program
Code so far:
@echo off
color 0c
:start
cls
cls
:correct
cls
goto command
:command
goto next
:next
set/p pwd=""
if %pwd%==q exit
if %pwd%==Q exit
:start2
cls
set/p pth="Path: "
cls
echo Copying...
echo.
echo Copy Complete!
echo.
exit
Step 6: FINISHED
color 0c
:start
cls
cls
:correct
cls
goto command
:command
goto next
:next
set/p pwd=""
if %pwd%==q exit
if %pwd%==Q exit
:start2
cls
set/p pth="Path: "
cls
echo Copying...
echo.
echo Copy Complete!
echo.
exit
and theres your code a bit more complete
*REMEMBER* - files save to data in same file as COPY.bat
now open up the file and test it
If you want a version with a bit more in it that is my personal one heres a download of it:
http://www.mediafire.com/?79190daueu9r73i
