Introduction: Batch File: Discord Token Generator
Here I have created a random token generator for discord. Basically, what a token in discord does is it's the line of random text (that actually isn't completely random if you look at it enough) that defines every account on discord. Note that any things you do with these tokens are not my responsibility and you are to take responsibility for the actions you commit. Also note that some of the generated tokens may not work, but some do, I tested a few myself using a program (I did not use them in any harmful way). It is not my fault if you decide to break discord TOS with the generated tokens. With that out of the way, here is my discord token generator made with pure batch script.
Windows 10
Step 1: Make a Text File
As always, make a text file to begin with and open it up.
Step 2: Copy Code
After making and entering your text file, just copy paste this coding:
@echo off
title Token Generator
:trigger
set trigger=57
:genKeys
set /a trigger=%trigger% - 1
set /a choose=(%random%*3/32767)+1
if %choose% == 1 goto lowercase
if %choose% == 2 goto uppercase
if %choose% == 3 goto number
:lowercase
set /a lower=(%random%*25/32767)+0
if %lower% == 0 set gen%trigger%=a
if %lower% == 1 set gen%trigger%=b
if %lower% == 2 set gen%trigger%=c
if %lower% == 3 set gen%trigger%=d
if %lower% == 4 set gen%trigger%=e
if %lower% == 5 set gen%trigger%=f
if %lower% == 6 set gen%trigger%=g
if %lower% == 7 set gen%trigger%=h
if %lower% == 8 set gen%trigger%=i
if %lower% == 9 set gen%trigger%=j
if %lower% == 10 set gen%trigger%=k
if %lower% == 11 set gen%trigger%=l
if %lower% == 12 set gen%trigger%=m
if %lower% == 13 set gen%trigger%=n
if %lower% == 14 set gen%trigger%=o
if %lower% == 15 set gen%trigger%=p
if %lower% == 16 set gen%trigger%=q
if %lower% == 17 set gen%trigger%=r
if %lower% == 18 set gen%trigger%=s
if %lower% == 19 set gen%trigger%=t
if %lower% == 20 set gen%trigger%=u
if %lower% == 21 set gen%trigger%=v
if %lower% == 22 set gen%trigger%=w
if %lower% == 23 set gen%trigger%=x
if %lower% == 24 set gen%trigger%=y
if %lower% == 25 set gen%trigger%=z
if %trigger% == 0 goto keys
goto genKeys
:uppercase
set /a upper=(%random%*25/32767)+0
if %upper% == 0 set gen%trigger%=A
if %upper% == 1 set gen%trigger%=B
if %upper% == 2 set gen%trigger%=C
if %upper% == 3 set gen%trigger%=D
if %upper% == 4 set gen%trigger%=E
if %upper% == 5 set gen%trigger%=F
if %upper% == 6 set gen%trigger%=G
if %upper% == 7 set gen%trigger%=H
if %upper% == 8 set gen%trigger%=I
if %upper% == 9 set gen%trigger%=J
if %upper% == 10 set gen%trigger%=K
if %upper% == 11 set gen%trigger%=L
if %upper% == 12 set gen%trigger%=M
if %upper% == 13 set gen%trigger%=N
if %upper% == 14 set gen%trigger%=O
if %upper% == 15 set gen%trigger%=P
if %upper% == 16 set gen%trigger%=Q
if %upper% == 17 set gen%trigger%=R
if %upper% == 18 set gen%trigger%=S
if %upper% == 19 set gen%trigger%=T
if %upper% == 20 set gen%trigger%=U
if %upper% == 21 set gen%trigger%=V
if %upper% == 22 set gen%trigger%=W
if %upper% == 23 set gen%trigger%=X
if %upper% == 24 set gen%trigger%=Y
if %upper% == 25 set gen%trigger%=Z
goto genKeys
:number
set /a number=(%random%*9/32767)+0
set gen%trigger%=%number%
goto genKeys
:keys
cls
echo %gen56%%gen55%%gen54%%gen53%%gen52%%gen51%%gen50%%gen49%%gen48%%gen47%%gen46%%gen45%%gen44%%gen43%%gen42%%gen41%%gen40%%gen39%%gen38%%gen37%%gen36%%gen35%%gen34%%gen33%%gen32%.%gen31%%gen30%%gen29%%gen28%%gen27%%gen26%.%gen25%%gen24%%gen23%%gen22%%gen21%%gen20%%gen19%%gen18%%gen17%%gen16%%gen15%%gen14%%gen13%%gen12%%gen11%%gen10%%gen9%%gen8%%gen7%%gen6%%gen5%%gen4%%gen3%%gen2%%gen1%%gen0%
pause >nul
goto trigger
@echo off
:trigger
set trigger=57
:genKeys
:lowercase
goto genKeys
:uppercase
goto genKeys
:number
goto genKeys
:keys
cls
pause >nul
goto trigger
Step 3: Publish Program
Now after pasting the code and saving the file, change the file extension from ".txt" to ".bat". Previously I have ran into the issue with newer windows OS having the extension hidden making it so that just renaming the extension doesn't change the file type. If you have this issue then open up command prompt by searching on your PC "CMD", then once in command prompt type the command "ren {file path} {file name}.bat" (enter the requested texts into the "{}" tags and get rid of the symbols of course).
