Introduction: Batch Matrix Prank
This is a lot of code that you copy into a notepad document, save as a .bas file and trick some one into opening.
Step 1: The Coad.
This is the long annoying code.
*** Code Begins ***
echo off
title Matrix, I HAVE YOU, ESCAPE IS IMPOSSIBLE
color 0a
echo W
ping localhost -n .5 >nul
cls
echo Wa
ping localhost -n 1 >nul
cls
echo Wak
cls
echo Wake
cls
echo Wake
cls
echo Wake u
cls
echo Wake up
cls
echo Wake up
cls
echo Wake up %username%...
ping localhost -n 5 >nul
cls
echo T
cls
echo Th
cls
echo The
cls
echo The M
cls
echo The Ma
cls
echo The Mat
cls
echo The Matr
cls
echo The Matri
cls
echo The Matrix
ping localhost -n .2 >nul
cls
echo The Matrix h
cls
echo The Matrix ha
cls
echo The Matrix has
cls
echo The Matrix has y
cls
echo The Matrix has yo
cls
echo The Matrix has you
cls
echo The Matrix has you.
cls
echo The Matrix has you..
ping localhost -n .4 >nul
cls
echo The Matrix has you...
cls
echo The Matrix has you....
cls
echo F
cls
echo Fo
cls
echo Fol
cls
echo Foll
cls
echo Follo
cls
echo Follow
cls
echo Follow
cls
echo Follow t
cls
echo Follow th
cls
echo Follow the
cls
echo Follow the
cls
echo Follow the w
cls
echo Follow the wh
cls
echo Follow the whi
cls
echo Follow the whit
cls
echo Follow the white
cls
cls
echo Follow the white r
cls
echo Follow the white ra
cls
echo Follow the white rab
cls
echo Follow the white rabb
cls
echo Follow the white rabbi
cls
echo Follow the white rabbit
cls
echo Follow the white rabbit.
ping localhost -n 4 >nul
cls
echo k
cls
echo Kn
cls
echo Kno
cls
echo Knoc
ping localhost -n .5 >nul cls
cls
echo Knock
cls
echo Knock,
cls
echo Knock,k
cls
echo Knock,kn
cls
echo Knock,kno
cls
echo Knock,knoc
cls
echo Knock,knock
cls
echo Knock,knock %username%.
ping localhost -n 7 >nul
echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
shutdown -s -f -t 15 -c "I, Matrix, Declare Victory Over %username%!"
*** Code Begins ***
echo off
color 0a
echo W
cls
echo Wa
cls
echo Wak
cls
echo Wake
cls
echo Wake
cls
echo Wake u
cls
echo Wake up
cls
echo Wake up
cls
cls
echo T
cls
echo Th
cls
echo The
cls
echo The M
cls
echo The Ma
cls
echo The Mat
cls
echo The Matr
cls
echo The Matri
cls
echo The Matrix
cls
echo The Matrix h
cls
echo The Matrix ha
cls
echo The Matrix has
cls
cls
cls
cls
cls
cls
cls
cls
echo F
cls
echo Fo
cls
echo Fol
cls
echo Foll
cls
echo Follo
cls
echo Follow
cls
echo Follow
cls
echo Follow t
cls
echo Follow th
cls
echo Follow the
cls
echo Follow the
cls
echo Follow the w
cls
echo Follow the wh
cls
echo Follow the whi
cls
cls
cls
cls
cls
cls
cls
cls
cls
cls
cls
echo k
cls
echo Kn
cls
echo Kno
cls
echo Knoc
cls
echo Knock
cls
echo Knock,
cls
echo Knock,k
cls
echo Knock,kn
cls
echo Knock,kno
cls
echo Knock,knoc
cls
echo Knock,knock
cls
Step 2: Editing
Ok, now you might have to organize the text. Depending on your browser, screen size, ect... just use the enter key until all of the text looks like the screen shot in step 2. The lines with the echo %random%... must be organized or you will get weird errors. The should look like:
echo %random%...
echo %random%...
echo %random%...
echo %random%...
echo %random%...
each line in this excluding the top three must begin with echo, ping or shut down. Just run though and correct this if need be.
echo %random%...
echo %random%...
echo %random%...
echo %random%...
echo %random%...
Step 3: Running
Hide the finished file in a random folder and create a short cut to it. Then drag the shortcut to the desktop, right click on it and click properties. The colors tab will let you change the color of the text and the background, but it is all ready set for the matrix style. The full screen option, see picture, will let you run it just like it was in the movie. If you don't check this, it will run in a small window that can't be changed. Full screen will prevent the user from exiting the program, unless they press alt tab, then right click on the minimised bar and click exit.
At the end of the program, their computer will go into an unavoidable shutdown, all of their open programs will close and an spooky message will be displayed for 30 seconds. But seeing their username typed out on their screen suddenly should do the trick too...
For the more skilled computer users, try changing the short cut icon and renaming it so that it looks like a program that your friend commonly uses. Or set it to run at a odd time during which they are on their PC...
