Introduction: Batch Guessing Game
instructions:
1.copy and paste step 2's text in to notepad
2. save as "your_name.bat" the ".bat" is crucial to the function of this game
Step 1: The Code
@echo off
color 0a
set/a one's=50
set/a two's=40
set/a three's=30
set/a four's=20
set/a five's=10
set/a six's=5
set/a seven's=1
echo Welcome to this useless two-player game in which one player picks a number
echo.
echo between 1 and 100 and the other player tries to guess it. Player 1 makes the
echo.
echo number and player 2 tries to guess it. You will be given NO hints or clues.
echo.
pause
cls
echo Enter the name for each player.
set/p "pone=Player one>"
echo.
set/p "ptwo=Player two>"
cls
goto ar
:busted
cls
echo I SAID a number between 1 and 100!
echo.
:ar
echo OK %ptwo%, look away. %pone%, type in the number and press enter.
set/p "deguess=>"
if %deguess% GTR 100 GOTO busted
cls
echo Choose a difficulty, %ptwo%:
echo.
echo (1) piece of cake-50 guesses
echo (2) easy-40 guesses
echo (3) moderate-30 guesses
echo (4) a little tricky-20 guesses
echo (5) hard-10 guesses
echo (6) insane-5 guesses
echo (7) impossible!-1 guess
echo.
echo Type the number of the difficulty you would like to play.
echo.
set/p "diff=>"
if %diff%==1 GOTO 1
if %diff%==2 GOTO 2
if %diff%==3 GOTO 3
if %diff%==4 GOTO 4
if %diff%==5 GOTO 5
if %diff%==6 GOTO 6
if %diff%==7 GOTO 7
:1
cls
goto br
:no21
cls
echo NOPE!
echo.
:br
echo Guess in the space below. You still have %one's% guesses.
set/p "guess41=>"
if %guess41%==%deguess% GOTO success
set/a one's=%one's%-1
if %one's%==0 GOTO failure
goto no21
:2
cls
goto cr
:no22
cls
echo NOPE!
echo.
:cr
echo Guess in the space below. You still have %two's% guesses.
set/p "guess42=>"
if %guess42%==%deguess% GOTO success
set/a two's=%two's%-1
if %two's%==0 GOTO failure
goto no22
:3
cls
goto dr
:no23
cls
echo NOPE!
echo.
:dr
echo Guess in the space below. You still have %three's% guesses.
set/p "guess43=>"
if %guess43%==%deguess% GOTO success
set/a three's=%three's%-1
if %three's%==0 GOTO failure
goto no23
:4
cls
goto er
:no24
cls
echo NOPE!
echo.
:er
echo Guess in the space below. You sill have %four's% guesses.
set/p "guess44=>"
if %guess44%==%deguess% GOTO success
set/a four's=%four's%-1
if %four's%==0 GOTO failure
goto no24
:5
cls
goto fr
:no25
cls
echo NOPE!
echo.
:fr
echo Guess in the space below. You still have %five's% guesses.
set/p "guess45=>"
if %guess45%==%deguess% GOTO success
set/a five's=%five's%-1
if %five's%==0 GOTO failure
goto no25
:6
cls
goto gr
:no26
cls
echo NOPE!
echo.
:gr
echo Guess in the space below. You have %six's% guesses left.
set/p "guess46=>"
if %guess46%==%deguess% GOTO success
set/a six's=%six's%-1
if %six's%==0 GOTO failure
goto no26
:7
cls
echo Guess in the space below. You only have %seven's% guess.
set/p "guess47=>"
if %guess47%==%deguess% GOTO success
goto failure
:success
cls
echo Well done, %ptwo%! You may now exit the game.
color 0c
color 09
color 0e
goto success
:failure
cls
echo %pone%'s number was too difficult. Sorry, %ptwo%.
echo.
echo The number was %deguess%.
echo.
pause
Step 2: A Cheat?
none so far that i know but i made a guessing game on my ti-83 plus which contains a loophole (the code must be put in to a ti 80 type calculator)
code:
menu("pick","1P',1,"2P",2,)
lbl 1
clrhome
randInt(1,1000)-> n ((do not include) cant represent the arrow to declare the var)
disp "guess a number"
for(i,1,10)
input "guess",g
if n=g
then
disp "you got it!",guesses:",i
pause
stop
else
if n>g
then
disp "higher"
else
disp "lower"
end
end
end
disp "you lose!","the number was:",n
stop
lbl 2
disp "P2 pick a number","1-1000"
prompt n
if n>1000
goto 2
else
clrhome
for(i,1,10)
input "guess",g
if n=g
then
disp "you got it!",guesses:",i,"num",n
pause
stop
else
if n>g
then
disp "higher"
else
disp "lower"
end
end
end
stop
that's all the code
its a fun game with 2 modes 1 player 2 player
the cheat is when it says guess a number click alpha log/10x/N
n is the variable that contains the answer so each game mode has this loop hole
