Bathroom Alarm
Intro: Bathroom Alarm
The Emergency Potty Alarm is perfect for anyone who regularly goes through the discomfort and frantic suspense of waiting for someone to get out of the bathroom when desperately in need of a toilet. The Emergency Potty Alarm system has a push button located just outside the bathroom door. When the button is pushed, an alarm sounds inside the bathroom, alerting the occupant that someone is desperately waiting. The alarm turns off automatically once the door is opened.
Enjoy!
STEP 1: Components
Circuit Components
Arduino (I used the Arduino Uno)
Breadboard
Resistors: 1x (brown blue green), 2x (brown black orange), 1x (red, red, red)
Transistor
Wires - 4 Different Colors (I used red, black, yellow, and green)
4-Way DC Power Splitter (You only use two of the splitters, so use a 2-Way splitter if you have one).
Breadboard-Friendly DC Barrel Jack
Soldering Equipment
Suggested Box Components - Laser cutter required
12" x 18" 1/8 White Acrylic
Misc
3M Removable Mounting Squares
Alligator Clips
Electrical Tape
Measuring Tape
Masking Tape optional
Box to house circuit (I used a box I found around the house)
Method to Make Vinyl Stickers (I used an Epson Vinyl Printer Cutter)
STEP 2: Code and Circuit
The code is fairly straightforward.
Notes on Wiring
Door Switch
The door switch can be thought of as a button for wiring and coding purposes. It uses a pull-up resistor. It does not matter which wire goes to positive or negative.
Massive Arcade Button
The button has two prongs for the LED and two prongs for the button. The two prongs on the sides are for the LED, and the two uneven prongs are for the button. For the button function, the protruding prong is positive, and the inset pin is negative.
It's easiest to color code each of the prongs with a different colored wire. I used:
Red: LED Power - to Pin 7
Black: LED Ground - to ? k resistor
Yellow: Button Power - to ? k resistor
Green: Button Ground - to ground
STEP 3: Making the Box
Design box and laser cut it! There are a lot of great websites that generate box plans for free. I used http://www.makercase.com and then added a hole to screw in the button and a wire hole. I've attached the file I used, but it could use some tinkering.
To attach the button to the box face, remove the washer from the back of the button. Slide in the wall, and screw the washer in on top.
Glue the box together along the seams, with the exception of the button face. DO NOT GLUE ON THE BUTTON FACE.
Put the wires through the wire hole on the bottom face. Snap the top face in.
STEP 4: Reducing Siren Volume
If the siren sounds a little too loud, which it might, you can unscrew the bottom, and place masking tape over the speaker.
STEP 5: Measuring and Soldering
Figure out where you want to place the front button, the siren, and locate the power outlet that will charge the Bathroom Alarm. There is typically more space under the door, so measure for the wires going under the door.
It's easiest to make the wires longer than you think you will need, and then trim them at the end.
Solder the wires appropriately. Make sure to wrap the individual siren wires in electrical tape to keep them from shorting.
Bundle the wires for each of the sensors by wrapping them in electrical tape every few inches.
Once the circuit is working correctly, use electrical tape along the button box to add a decorative element and secure the front face.
STEP 6: Stickers!
Print and attach stickers to button and alarm. (File coming shortly).
STEP 7: Mounting
For a quick, temporary, and damage free solution, you can use Scotch Temporary Mounting Squares. Each pack has 64 squares, so you only need to buy one pack.
Adhere the following number of mounting squares:
2 each for door sensors
8 for alarm
16 for button
STEP 8: Box for Circuit
If desired, get a box and drill holes appropriately for your setup. I used a cardboard jewelry box.
STEP 9: Finishing Touches
Tape wires along the wall using electrical tape.
Admire your handiwork.
3 Comments
ClenseYourPallet 8 years ago
Theturkeytree 8 years ago
If you're planning to camp out in the bathroom, I suggest keeping a pair of very good earplugs handy :)
seamster 8 years ago
This is pretty clever idea!
Although, the cruel and mean among us just might be inclined to take MORE time if we knew someone was waiting . . . :)
