Introduction: Batman Wall Clock
So over the last couple of weeks I have been making plans to decorate my godsons bedroom and he wanted a Batman themed room so thought I would start off easy and build him a Batman style wall clock.
Its actually pretty simple to make and relatively low cost, ended up costing about £4. Most of you will probably have everything you need just lying around, the only thing I actually needed to buy was a clock mechanism itself as wanted one with yellow hands.
Materials Required:
Paper version of your design
MDF or Plywood
Quartz Clock Mechanism
PVA & water (if using MDF)
Paint
Tools Required:
Hobby Knife
Jigsaw
Sandpaper
Pencil (optional)
Sticky Tape (optional)
Materials Required:
MDF or Plywood
Paint
Tools Required:
Hobby Knife
Jigsaw
Sandpaper
Pencil (optional)
Step 1: Choose Your Design
So I decided to make the clock the Batman logo shape so manage to find a decent image and enlarged it and printed it out on A3 paper
Then using some sticky tape I taped the design to a scrap piece of 6mm MDF I had lying around. A quick score around the edge of the design with the hobby knife left a nice impression on the MDF, which I then went over with a pencil so give me a good clean easy to see line to follow with the jigsaw.
Step 2: Cut Out the Design
Then using the jigsaw I carefully cut out the design. I had to using a coping saw in the end for the piece between the ears as my jigsaw blades were all a little large.
Once the design was cut out I went over all the edges with some sandpaper and ended up with nice smooth edges.
Step 3: Prep and Painting
The next step was to seal the edges of the MDF, so here I watered down a little PVA and brushed this carefully around the edges of the MDF. If any PVA got onto the front face of the design I wiped it off so I would not have to do any more sanding.
Once the PVA was dry I then put on a base coat of 'Plasti-kote Super Matt' black paint which I had left over from a previous project. Once dry I lightly sanded this coat with some wet and dry and added a couple of final coats and ended up with a really nice matt finish.
Step 4: Adding Quartz Mechanism
Once the paint was fully dried I then marked up where I wanted my clock hands to be, I managed to pick up a cheap clock mechanism from ebay fro £1.99 which came with yellow hands which was perfect for my clock, it already had a wall hanger built into the mechanism so didn't even need to worry about making something to hang the clock which was nice.
So once I drilled the hole for the hands (8mm in my case) was just very simple to add the clock mechanism, add the battery and hang it on the wall.
There you have it, a simple cheap wall Batman style clock, all for less than a fiver!
