Introduction: Battery Tester
This is a program designed for use with an arduino and a battery that does not exceed 5 volts.
You will need:
- an arduino
- a breadboard
- 10 wires
- 3 LEDs
- a battery of less than 5 volts
Step 1: Assembly
Follow the attached image for instruction on assembly.
Step 2: Program
float highT = 1;
float lowT = 0.5;
void setup() {
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
void loop() {
float a = convertVolts(analogRead(0))
if(a>highT){
digitalWrite(13, HIGH);
} else if(a>lowT){
digitalWrite(12,HIGH);
digitalWrite(13,LOW);
} else{
digitalWrite(11,HIGH);
digitalWrite(12,LOW);
float convertVolts(int b){
return((b/1024)*5);
Step 3: Different Batteries
If you wish to use a different battery, slight adjustments to the code can be made. To change the voltages considered high, medium, and low, simply change the variable highT, to whatever you wish the threshold for the battery to be considered high voltage, and lowT to whatever you wish to be the most charged the battery can be to be considered low.
NEVER use a battery that emits more than 5 Volts.
