Introduction: Battery Tester LED Display
Test battery voltage indicated by three LEDs; Green, high; Yellow, medium; Red, low.
Step 1: Build Circuit
What you will need:
- Arduino UNO
- Breadboard
- 3 LEDs, preferably red, yellow, and green. (I used an RGB LED since I didn't have a green LED)
- 4 330k ohm resistors
- 8 jumper wires
- 2 alligator clamps
- C Battery for testing
Step 2: Write Code to Read Battery Voltage
int sensorValue;
float voltage;
void setup() {
Serial.begin(9600);
pinMode(0, INPUT);
void loop(){
sensorValue = analogRead(0);
voltage = sensorValue * (5.00 / 1023.00); //convert the sensor read to a true voltage.
Serial.println(voltage);
Step 3: Write Code to Write Voltage to LEDs
int sensorValue;
float voltage;
void setup() {
Serial.begin(9600);
pinMode(0, INPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
void loop(){
LEDs();
void LEDs(){
if (voltage > .53) {
digitalWrite(11, HIGH); }
else if (voltage <.53) {
digitalWrite(13, LOW);
digitalWrite(12, LOW);
digitalWrite(11, LOW); }
if (voltage > 1.06) {
digitalWrite(12, HIGH);
else if (voltage <1.06) {
digitalWrite(12, LOW); }
if (voltage > 1.59) {
digitalWrite(13, HIGH);
else if (voltage <1.59) {
digitalWrite(13, LOW); }
