Introduction: Bead Wrapped Heart Earrings Tutorial
I have another tutorial again and this time it's making wire heart earrings ♥ Wit the same steps you can also make pendants and charms. All you have to do is make the heart shape bigger.
Step 1:
Cut about 9cm wire and make a loop at the center with a round nose pliers. Bend the wires up, making sure the wires are of the same length.
Step 2:
Then with a round object, in this case I used a pliers' handle make a curve by bending the wire downward. Do the same for the other wire.
Step 3:
After bending the wires you'll see that is starts to shape into a heart. Adjust the wires, if needed and then make a loop at both ends.
Step 4:
Then fill the heart with bicones. You can also use round beads if you like. With a thinner wire, first wrap the heart frame at least 2x and then slide in a bicone and then wrap again.
Step 5:
Continue wrapping until you fill the heart frame with bicones.
Step 6:
Then with the extra wire slide in a bigger round bead and wrap the other end onto the heart frame to secure it. Cut off excess wires.
Step 7:
Make one more heart with the same steps and attach your ear wires. Voila! You've made yourself a bead wrapped heart earrings ♥ Hope you like the design. It's really cute!
I have posted the complete steps on my blog. You also have the option to download a PDF copy if you like ♥ Have fun!
