Introduction: Beaded Button Jewelry Component
This is a fun use for using a button as a component in jewelry and other crafts.
Step 1: Supplies, Tools, Technique
Supplies:
- 3 1/2 cm Button
- 1 - 2 colour of seed beads 11̊ Delica Seed Beads
- For this project
- 856- Mat Transparent Fire Red (AA)
- 734- Dark Chocolate (BB)
- For this project
- Thread
- Optional
- Split Ring
Tools
- Beeswax/Thread Conditioner
- #10 needles
- Scissors
Technique
- Circular netting
Step 2: First Row
- Prepare a length of thread.
- String a stop bead.
- Add 48 AA.
- Or, string 2AA and 1 BB until you total 48 beads.
- Or, if you are using a different size button, you will need to increase or decrease the number of beads in this row.
- Make the adjustment in groups of 3 beads.
- Go through the first bead in the same direction to make a large loop.
- This loop will be smaller than the button but look like it would be closer the button edge.
Step 3: Second Row
- If using accent beads in this row, exist at the first AA.
- String AABBAA.
- Skip 2 AA and go through the third bead.
- If you are using accent beads in this row, go through the next BB.
- Keep your thread taunt.
- Repeat the entire circumference of the loop.
- Go back to the first row and run your needle though again to ensure a tight loop.
- Now step up to start row 3.
- Exit BB in one of the first AABBAA of 2nd row.
Step 4: Third Row
- String 2AABB2AA.
- There will be a total of 5 beads.
- Go through BB of the next loop.
- Repeat the pattern for the entire circumference of the loop.
- Now step up to start row 4.
- Exit BB in one of the first 2AABB2AA of this row.
Step 5: Fourth Row
- String 3AABB3AA.
- There will be 7 beads.
- This row will fold up the side of the button.
- Check the fit with the button.
- Now step up to start row 5
- Exit BB in one of the first 3AABB3AA of this row.
Step 6: Fifth Row
- String 2AABB2AA.
- There will be 5 beads.
- This row will be the start of the face of the button.
- As this is the decrees this is also the row that first ensnares the button.
- Hold the button in the beaded cage.
- Repeat the pattern for the entire circumference of the button.
- Keep your thread taught.
- Now step up to start row 6.
Step 7: Sixth Row
- Alternate 4AA’s with 3AA’s around the circumference of the button.
- String 4AA and go through the next BB.
- String 3AA and go through the next BB.
- You want this row to lay flat along the top of the button.
- You may have to decrease 1AA occasionally to get this row to pay right.
- Exit at the first BB to start row 7.
Step 8: Seventh Row
- String AA and go back through the AA.
- This will create a picot.
- Go through the next section of AA’s to the next BB and repeat a picot.
- Continue this for the circumference of the button.
- Keep it tight to help hold the button in.
- You want to keep the beads snug as you cage the button.
- When you get back to the beginning you will exit the first picot.
- You will now be working in the opposite direction that you were originally.
- If you were working clockwise then you want to go counter clockwise.
- You will string 4AA and go through the next picot BB.
- You will be stacking these new sets besides their counterparts in row 6.
- String 3AA and go through the next picot BB.
- You will have to decrease 1AA occasionally to get this row to lay right.
- You will be more likely to need to do a decrease on this row.
- Repeat the entire circumference of the button.
- Run your thread through this row again pulling everything tight.
Step 9: Finish
- Tie off all ends.
- Trim loose threads.
- Finished buttons can be sewn together to make a chain or in a stacked pattern.
- A bead loop can be added for a pendant.
- Sew on split rings to add other finding.
