Introduction: Beautiful Paper Flowers
Hi friends, Today am going to show you how to make beautiful paper flowers.
Seeing vase full of flowers in our work table will be colorful to your eyes, i tried making it first time and its working a lot.
Don't wait, grab your scissors and papers and start filling your vase with flowers.
Step 1: Items Needed
We need only 6 items to make these paper flowers.
1, Color paper of your choice
2, Wire cutter
3, Floral wire
4, Glue or Feavicol
5, Small sticks
6, Waste newspaper
Step 2: Preparing Petals ( Type 1 )
1, Cut the paper in to equal sizes and make it as a shape of Petals.
2, paste the petals each other, one by one, have 5 petals pasted each other. Refer image 4, 5, 6, 7, 8
3, Joint the petals using glu. Refer image 9
4, Let it dry for 5 minutes, once its dried it will look like Image 10 and 11.
5, Once the flower is dried cut half cm in between each petals like image 12 and 13.
6, Once Cut is made just pull the petals outward to look like actual flower. Refer image 14
Step 3: Preparing Petals ( Type 2 )
2, Paste the petals each other, one by one, have 10 petals pasted each other for first layer.
3, For second layer keep 9 petals and paste each other.
4 For third layer keep 8 Petals and paste each other.
5, follow the step until you reach 4 petals. Refer image 1, 2, 3
6, joint the ends using glu, once it done it will look like image 6, 7, 8.
7, Prepare the filament by wrapping a paper on the end of small stick like image 9, 10, 11.
8, now apply glu in filament and insert the petals we prepared, start from the lowest petals. Don't forget to apply glu after adding each petal. Refer image 12, 13
9, Once all petals were added it will look like image 14.
Step 4: Preparing Filament and Ovules
1, Take a fiber and cut to two equal sizes
2, take piece of paper and apply Feavicol and and keep the fiber pieces and just wrap it tight in a small piece of stick. Refer image 3, 4, 5, 6, 7, 8
3, you can also remove filaments if you don't have a fiber. in image 9, 10, 11, 12 i have make only ovules.
Step 5: Attaching the Filament, Ovules With Petals
1, Hold the stick and apply glu at the bottom of ovule refer image 6.
2, Now insert the stick inside the petals, refer image 7.
3, Once its attached it will look like image 4 and 5.
Step 6: Prepare Different Flowers With Different Colours
1, Use different colors to make flowers, try dark colors.
2, Its our creativity, so try different style of petals, colors etc.
Step 7: Attaching the Flowers With Bark
1, User floral wire as bark, have small bend to wire so that it look like actual bark. see image 1.
2, Add one flower at each bend and secure it with glu or floral tape. refer image 2, 3, 4, 5.
Step 8: Prepare 4 to 5 Set of Barks With Full of Flowers.
1, I have made 5 set of flowers, i haven't used leaf as i didn't get green color in a shop.
2, you can attach leaf to each bark to look it like real flowers.
3, Actually i don't have a Vase so I made a Small vase with White cement couple of months before, so am using that vase to arrange my paper flowers.
Step 9: That's It Flower Vase Is Ready.....
I have arranged those flowers in my vase, it look so beautiful, and my mom and dad was astonished by looking this.
Again its our creativity, you can make it like flower vase or a Bonsai plant, or wall hanger etc.
I hope this would be very helpful to you all.
Thank you friends see you soon.
