Introduction: Beautiful Steam Punk Valve LED Lighting
How to make a fantastic looking retro steam punk style battery powered lamp from parts from an old valve radio system!
All the steps for this are detailed in this instructable. There are two YouTube videos included from my channel so you can see how effective this looks and how easy it is to make. I'm sure you will put your own spin on this project. The wiring is very simple.
Please subscribe to my instructables page to be notified of cool future projects, and also please subscribe to my YouTube channel to see other mad projects that we get up to!
Howard
如何善用舊真空管無線電系統零件做一個以電池供電的夢幻復古蒸汽龐克風格燈!
所有步驟會在這裡詳細說明。我在YouTube視頻中分成二段影片,因此您可以看到它的效果如何,以及它的作法有多麼簡單。 我相信你將會用自己的方式來詮釋這個企劃。 它的接線是非常簡單。
請訂閱我的instructables網頁,以利收到未來新項目的通知,還有也請訂閱我的YouTube頻道,查看其他瘋狂的項目!
Step 1: Salvage the Parts 零件廢物利用
Open the case and remove the valves and the coils from the vintage radio!
打開老式收音機外殼,並從中取出真空管和線圈!
Step 2: Design Your Lamp
Cut up a block of wood to mount the lighting, batteries and valves.
Place the lights and valves where they are most appealing to the eye. Make sure the LEDs are close to the valves to it looks like the valves are turned on when everything is lit up!
切下一塊木頭來安裝燈光,電池和真空管。
將燈光和真空管放在最引人注目的位置。 確保LED燈靠近真空管,這樣當所有東西亮起來時,真空管看起來也像是被開啟了!
Step 3: Drill Holes and Fit Parts 鑽孔和安裝零件
Drill appropriate holes for the valves and LEDs, and glue the parts in place in preparation for wiring.
為真空管和LED燈鑽孔,並將零件黏合到準備配線的位置上。
Step 4: Start Wiring 開始配線
Once all the parts are fitted, start wiring the circuit with your soldering iron. The attached schematic is an example of how my circuit works.
一旦安裝好所有零件,請用烙鐵開始配置線路圖。 附上的概要圖是我的線路圖範例。
Step 5: Finishing the Design 完成設計
Wrap insulation tape on the batteries and over the cables & connections to shield them from possible short circuits.
Use linseed oil to make the wood grain standout like a french polish!
在電池和電纜上纏繞絕緣膠帶,以防止它們發生短路。
使用亞麻子油使木頭的紋理更顯現,就像法式拋光!
Step 6: Wrapping and Decorating
Wrap copper wire, fit coils and decorate your lamp using hot-glue and parts from your old valve radio! Make it look beautiful and interesting!
