Introduction: Beautiful Flowerpot Covered With Reed
Want some decoration and you have lot of space?! This flowerpot covered with reed will find some space at your garden.Its easy to make and you don't need to spend to much money.
MATERIALS:
-Pot
-Reed
and some metal wire
TOOLS :
-pliers
Step 1: Step 1 : Getting Materials and Dimensions
So first you need to find some old pot,reed and metal wire..
It doesn't matter how big will be the flowerpot...
Next you need to find reed.. Then you will cut enough pieces for the flowerpot. They need to have the same dimensions as the flower pot ..
The metal wire needs to be big enough so it can go around the pot.
Step 2: Step 2 : Building the Flowerpot
First you need to put 2 pieces of wire around the pot.. make sure to secure the wire so it wont fall and to have little space so you can put the reed between the pot and the wire!
Then slowly and careful put the reed..
and finally when you will have reed all around the pot, make sure that there is no empty space..
Then tie the wire even stronger and place in your garden!
ENJOY !!
Step 3: Step 3 : Put Some Flowers and ENJOY
Now you can cover anything with reed!
Be creative and build something!
I hope you guys like this instructable I had so much fun making this!
Give it a try ;)
